location for wb o2
i would likt to know the CORRECT placement also, i know my bung is in the dp about 10" off the exhaust side of the turbo, but i dunno if thats the CORRECT place
think about it. If the exhaust is in a confined space traveling in one direction, the AFR isnt going to change at all. I have always understood that putting it a little farther down the pipe ensures the afr is even in a given amount of space. (all the way mixed if you will) Plus its a little bit cooler a little farther away.
you def dont want the wideband at the end of the downpipe. If its too close, you will get a lean reading. How far to keep it from the end of the downpipe, i donno, 8-10 iches maybe more ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jfoster »</TD></TR><TR><TD CLASS="quote">Does having an open dump tube affect the accuracy of the WB as apposed to having it tie back into the DP ???</TD></TR></TABLE>
nope
nope
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adictionbass »</TD></TR><TR><TD CLASS="quote">you def dont want the wideband at the end of the downpipe. If its too close, you will get a lean reading. How far to keep it from the end of the downpipe, i donno, 8-10 iches maybe more ? </TD></TR></TABLE>
so mine is too close. Prolly 10" from the turbo ... dump tube not tied back in ... so am I actually running richer than its tellin me ??
No, i meant to close to the end of the down pipe (fresh air can circulate into the downpipe and cause a lean reading). Nothing to do with being too close to the turbo
