IAT's and knocking????
Old Mar 27, 2006 | 09:01 AM
bdavis's Avatar
Default IAT's and knocking????
tuning my car with the gsr head and having some knock issues.
poly intake gasket
chrome pro - p72 code
gsr mani
t3/t04b
its about 40 deg out and my iats only reach about 70 deg according to my temp sensor via crome pro. i thought it would be hihger. low boost is about 10psi - runs perfect no knock from 3000-8000 rpm
17psi it knocks like a bitch as soon as i get into boost till about 5500 rpm, then no know and away it goes. i have retarded timing down REAL low, like 5 degs and it still knocks, added a lot more timing and knock gets less but its still pulls about like 3-5deg, turn off knock sensor and it still hesitates around there, but then pulls like normal.
i am really confused and getting to my wits end. i check the pulgs all the time bkr7e's gapped to .025. but last night it looked like some small silverish speckling, which i assume to be knock. i think im gonna check out making a det can and see what i can hear
any suggestions or opinions
Old Mar 27, 2006 | 09:51 AM
mrx's Avatar
mrx
Default Re: IAT's and knocking???? (bdavis)
how much octane, what compression ratio do you run?
t3/t04b, maybe out of efficiency -> causing higher iat's? -> causing knock?
how much total timing do you running now?
is your distri set correctly?
Old Mar 27, 2006 | 11:27 AM
bdavis's Avatar
Default Re: IAT's and knocking???? (mrx)
94 octane: about 10:1 with ls bottom end, gsr head, stock hg
iat's are real low, lower than i would tend to think, which makes me curious to if maybe the engine is adding timing cause of cool air. not out of range for t3/t04b, should be in a pretty sweet spot
total timing can be as low (if not lower) as 5 deg and its still knocks.
dizzy is set perfect
i am so lost
Old Mar 28, 2006 | 09:24 AM
bdavis's Avatar
yea something is up in either the circuit board or in my wiring even though i shielded the wire. i switched ks last night and started a new map and had to pull over 10deg of timing in partial throttle to get it to quit knocking.
expletive it, i turned it off!
Old Mar 28, 2006 | 11:08 AM
ccivic's Avatar
Honda knock sensors are about worthless. I'd just make sure you're atleast a degree or so from the knock threshold and have all of your compensation tables setup well.
Old Mar 28, 2006 | 12:18 PM
bdavis's Avatar
Default Re: IAT's and knocking???? (ccivic)
The compensation tables seem to be set up well, im hitting the dyno tomorrow, so i should hopefully be able to fgiure out the timing a bit better then.
wish me luck!
98vtec
Aug 18, 2006 07:12 PM
I makes it RAIN
10
May 2, 2006 04:32 AM
bdavis
Feb 5, 2006 08:27 AM
bdavis
Feb 3, 2006 12:10 PM
sshaikh01
Feb 8, 2002 08:32 AM
