Cams for high boost applications???
Old Jul 11, 2006 | 11:37 AM
9hatchman4's Avatar
Default Cams for high boost applications???
Hey everyone, I'm just wanting to know what cams everyone is using for high boost applications? I'm running a gsr motor with the supertech valvetrain and was wondering if I should keep the stock gsr's or switch it up. I'd like to rev a little over stock since I'm running quite a large turbo, and it is going to spool late. Let me know, and thanks for the help.
Old Jul 11, 2006 | 11:38 AM
Turbocivic94's Avatar
Default Re: Cams for high boost applications??? (9hatchman4)
ITR/CTR
Old Jul 11, 2006 | 11:45 AM
9hatchman4's Avatar
Default Re: Cams for high boost applications??? (Turbocivic94)
Thanks for the info, anyone else, trying to get a little poll here lol, so I can try to decide.
Old Jul 11, 2006 | 11:59 AM
hybridEj6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbocivic94 &raquo;</TD></TR><TR><TD CLASS="quote">ITR/CTR</TD></TR></TABLE>
Old Jul 11, 2006 | 12:51 PM
9hatchman4's Avatar
Default Re: Cams for high boost applications??? (hybridEj8)
So I'm thinking everyone is liking the ITR cams huh, what are you guys revving to with those?
Old Jul 11, 2006 | 01:49 PM
hybridEj6's Avatar
It depends on if you upgrade your valvetrain or not.....if your valvetrain is stock...then keep it at the stock redline
Old Jul 11, 2006 | 02:05 PM
9hatchman4's Avatar
Yeah I'm gonna be running the full supertech valvetrain, 1 size over valves, dual valve springs, and titanium retainers.
Old Jul 11, 2006 | 02:38 PM
dome's Avatar
v1 cams
Old Jul 11, 2006 | 02:44 PM
maxspeedhonda's Avatar
Default Re: Cams for high boost applications??? (dome)
i run ITR
Old Jul 11, 2006 | 03:16 PM
AIRIC's Avatar
blox b's
Old Jul 11, 2006 | 06:53 PM
T4eg's Avatar
well over 700whp with ITR cams here. I say keep it simple
Old Jul 11, 2006 | 07:10 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Cams for high boost applications??? (T4eg)
540whp right now with gsr cams, 84mm b16 t3t67ho.
goin with mazworx v1's. thought about itr/ctr, but james gave me a hell of a deal on them.
Old Jul 11, 2006 | 07:18 PM
Joseph Davis's Avatar
GSR/ITR is pretty much what you're going to hear. FYI, CTR is the same thing as 00-01 USDM ITR, so don't even bat an eye if you want to go thqat route, just order it.
I have a friend running the RM M20/M21 combo. The car hasn't seen a dyno, but going from GSR cams it wanted ~3% less fuel on the high cam until 7000, and 7500-9500 wanted ~4% more fuel. Power band is definitely high, and car feels healthy. 2.0/VTEC, T67, 15 psi on 93 pump FWIW.
Old Jul 11, 2006 | 07:46 PM
bigbadboy's Avatar
i heard the V1 cams are good too. boostedcivicsir, make a post on the cam differences whenever you change out. i've been looking at cams as well but every1 says CTR but i know there is better. i'm interested to see if the V1's are better or not. let me know
Old Jul 11, 2006 | 07:58 PM
Mr. Badwrench
Default Re: (bigbadboy)
will do, i have a feeling my clutch will **** the bed with the cams and 33 psi though.
Old Jul 11, 2006 | 10:23 PM
IceySC's Avatar
wouldn't skunk2 stage 1 's be a good cam for boost safely cent's there almost the same as ctr?
Old Jul 12, 2006 | 05:10 AM
jetnbyu93's Avatar
I'm running ITR's and I have over 600whp
Old Jul 12, 2006 | 07:23 AM
TurboEM1's Avatar
Default Re: Cams for high boost applications??? (jetnbyu93)
ITR/CTR for high horsepower
GSR for a little lower horsepower
Old Jul 12, 2006 | 09:20 AM
9hatchman4's Avatar
Default Re: Cams for high boost applications??? (TurboEM1)
If I keep my gsr cams, and just upgrade the valvetrain, will I still be able to take it up a little higher in RPM's, like say to 9k? Or do I absolutely need to get different cams?
Old Jul 12, 2006 | 09:33 AM
HondaHead211's Avatar
CTR/ITR gets my vote
Old Jul 12, 2006 | 09:53 AM
TurboEM1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9hatchman4 &raquo;</TD></TR><TR><TD CLASS="quote">If I keep my gsr cams, and just upgrade the valvetrain, will I still be able to take it up a little higher in RPM's, like say to 9k? Or do I absolutely need to get different cams?</TD></TR></TABLE>
With an upgraded valvetrain you can take it higher. Its a matter of if the GSR cams will make power up to 9k which they should.
Old Jul 13, 2006 | 01:20 PM
dome's Avatar
yeah when i put my car on the dyno its going on there with stock gsr and then while im there im going to have them swaped out and put the v1's in. i cant wait to post that up lol.
Old Jul 13, 2006 | 02:17 PM
vaporboy12's Avatar
Default Re: (dome)
stock 01 spec usdm itr cams.. reving to 11,000
Old Jul 14, 2006 | 12:23 PM
J-Brooks's Avatar
Default Re: (dome)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dome &raquo;</TD></TR><TR><TD CLASS="quote">yeah when i put my car on the dyno its going on there with stock gsr and then while im there im going to have them swaped out and put the v1's in. i cant wait to post that up lol.</TD></TR></TABLE>
when si this going to be?
wrx-killer-Sti-eater
Dec 6, 2007 05:56 PM
King V
Oct 15, 2007 04:16 AM
the.hamburglar
Oct 29, 2006 11:12 AM
_gurusan_
Feb 5, 2005 10:48 PM
RC211V
May 21, 2002 02:53 AM
