alright 2 more questions, please don't flame me. Stock fuel pump and specs on something...
Alright, I purchased a used 99-00 si greddy turbo kit, precision 310cc injectors, and will have a new chip burned w/ turbo basemap for the B18c5 motor I'd put the turbo onto, blah blahblah, and have a few questions...
TDO5H-18G turbo internal WG setting, I've lookf or a while and can't seem to find.
I reallyw anna' run 5-6psi of boost for now
Wondering if I can run my stock fuel pump?
Modified by Naudlee at 2:53 PM 7/13/2006
anyone? and I also need help about Tuning... I'll have everythign installed, and idk how i'll get it to run right besides going to a dyno, I have a p28 chipped ecu if thats anyhelp...
get a walbro 255lph fuel pump, and also get a wideband so u can tune it....but if your only gonna run 5 or 6psi u can always buy an fmu and a missing link and just run on your stock injectors...i would recommend tuning it w/ your chipped p28 but the fmu is a cheap solution if u dont know how to tune your car
at 5-6 psi your stock fuel pump will last for a while. When you do get your walbro pump, a 190 is more than enough, you dont need the 255 unless your running alot more boost than 5-6 psi.
alright,t hanks. I don't [plan on running an FMU heard bad news about them and making your car shitout rather quickly... I don't need a missing link I'm told, seeing as I have the chipped ecu? Does anyone know whatthe internal WG of the snail is set at?
the wastegate is ajustable i belive. the tighter the rod the more boost, so i sugest loosing it almost all the way. stock is like 9-12 pounds i belive.
also with no tuning your asking to blow ur type-r motor.... gl and have fun
-joseph
-joseph
