is this injector usable? (dsm blue tops.)
ok i got this set of dsm blue tops for free so of course i took them.
but my problem is this....one of the tips is cracked as you can see in the pictures below, my question is would this injector be usable or to be safe should i look for a good one? i know its common sense and piece of mind but i was just wondering if its a big deal or not. let me know please thanks in advance
this is the cracked one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ghostskinner »</TD></TR><TR><TD CLASS="quote">yes its usable the cap can be changed</TD></TR></TABLE> well wouldnt it be pretty hard to find just the cap?
It might be hard to find but I imagine it could be done. Honestly I wouldn't even worry about it unless you put it in and it leaks.
Those thing spray directly from the pintle in the end so I doubt that crack is even going to effect anything.
Take them all off, they are just there to protect from damaging the needle. They do not affect spray pattern. They are so common for comming off, and i wouldn't want one comming off when i am at 8000 going down the track.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AaronJ »</TD></TR><TR><TD CLASS="quote">Take them all off, they are just there to protect from damaging the needle. They do not affect spray pattern. They are so common for comming off, and i wouldn't want one comming off when i am at 8000 going down the track.</TD></TR></TABLE> oh sweet this was deffinetly the answer im looking for, so taking them off wont mess with clearences or anything?
ok one more question, ill admit i am a complete boost noob, these "blue tops" i believe they are 450cc right? how much power are these usualy good for untill theyre maxed out?
Everyone and their mom has lost a pintle cap off a DSM injector. Some people have found replacements at Napa, although I didn't and had to buy a new set on ebay. Definitely don't leave the cracked one on because I've seen people do that before, then one day they pulled it out and the cap was gone, undoubtedly baked onto the piston top.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itsJDMbradyo! »</TD></TR><TR><TD CLASS="quote">ok one more question, ill admit i am a complete boost noob, these "blue tops" i believe they are 450cc right? how much power are these usualy good for untill theyre maxed out?</TD></TR></TABLE>
http://www.rceng.com/technical.htm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I Have an STD »</TD></TR><TR><TD CLASS="quote">yup, no need for them, they just protec the tip of the injector from damage. and yes they are 450cc and require the use of a resistor box</TD></TR></TABLE> yea i got the resistor box already
ok so im assuming these injectors will do fine at my 300-350HP goal?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Enzo Speed »</TD></TR><TR><TD CLASS="quote">I'd get 550's.</TD></TR></TABLE> well ima use these until i have to upgrade im sure i wont be hitting over 300WHP for a while, i havent even started piecin my turbo kit together yet hahaha
