1000cc obd2 injectors?
a local shop told me when i go turbo and need bigger injectors ill have to switch to obd1 clips is this true? also are the rc injector clips any good?
Re: 1000cc obd2 injectors? (DougieStyle)
1000cc? how much hp are you looking for?
i'm doing 1000cc and my goal is around 650hp.
if your going rc1000cc, rc clips or odb1 clips works. you can prolly get rc clips for like 25 bucks or dirt cheap if you go to junk yard and cut off clips from a obd1 honda
All the 1000cc injectors either RC or Precision are Peak and hold and you need a resistor box or injector driver box wired up , they alos use an OBD1 or Pre OBD clips sir. I seell eboth of these injectors if interested. Good luck
realis9
07-17-2007 02:30 PM
