accuracy of the narroband sensor
Old Jul 13, 2006 | 11:18 AM
chitownrida's Avatar
Default accuracy of the narrowband sensor
i've been boosted for a while with the basic drag kit inline pump and fmu
the car feels strong lowend, but will not pull much after about 4500 rpm
i noticed the narrowband af gauge sticks at around 13:1 when in full throttle
(when it was NA the narrowband went to 10:1 at full throttle)
should i be concerned?. been babing it ever since to preserve the motor.
advice
comments ? thanks in advance
Old Jul 13, 2006 | 12:03 PM
g2turbo's Avatar
Default Re: accuracy of the narrowband sensor (chitownrida)
I think its definitely inaccurate if it was showing 10:1 naturally aspirated.
Try borrowing a wideband or pay for an hour of dyno time to find out what the car is really doing. If it is 13:1 under boost that is too lean.
And you would be a lot happier with the car if you can get rid of the FMU and get some sort of management that allows fuel and timing contol. Your motor will love you for it too.
Old Jul 13, 2006 | 12:30 PM
Chris22215's Avatar
Default Re: accuracy of the narrowband sensor (g2turbo)
the narrow band uses a 0-1v scale which is only accurate for stoich (if that). Just get a wideband or pay for some dyno time
Old Jul 13, 2006 | 01:19 PM
2point2's Avatar
Default Re: accuracy of the narrowband sensor (Chris22215)
Old Jul 13, 2006 | 03:02 PM
turbotime's Avatar
narrowband o2 = pretty lights
wideband o2 = air/fuel ratio
get a wideband or get some dyno time to make sure ur afs are good. I suggest plxm300 for wb02
evilcivilian
Oct 4, 2004 04:48 PM
silverbulletgsr
Dec 27, 2003 11:32 AM
reaction360
Nov 23, 2003 11:58 AM
HybridCoupe
Jul 16, 2002 12:07 AM
Buzzbomb
Dec 27, 2001 09:56 PM
