oil feed line length
Old Jul 15, 2006 | 04:47 PM
Speed Infliction's Avatar
Default oil feed line length
how long does it need to be? I have a 36 inch line but i dont thik it will work. It will be coming off of an oil filter plate and going to the turbo on an AC ramhorn mani. let me know whats up guys
Old Jul 15, 2006 | 05:05 PM
Default Re: oil feed line length (Speed Infliction)
also can you cut these lines and make them shorter if you wanted to?
Old Jul 15, 2006 | 05:16 PM
Cramerox's Avatar
I think they should be as long as they need to be. I think the concern is if you will get enough pressure from that plate. I tapped mine from the back of the block and worked well also.
Depending on what type of oil line you are using, its definitly possible to make them shorter...its just depends if you have the tools to do so.
Old Jul 15, 2006 | 05:42 PM
Default Re: oil feed line length (Cramerox)
those oil plates don't carry good pressure?
Old Jul 16, 2006 | 04:34 PM
Cramerox's Avatar
I didnt say that they dont provide enough pressure- But i would find out. Ive seen a few people using them- so i guess it should be fine.
javantie
Apr 22, 2015 02:10 PM
StylishDOHC
Apr 4, 2006 09:02 PM
SuzukaBlueAP2
Jul 7, 2003 02:36 PM
Acura_I-RS
Mar 16, 2003 04:45 PM
LudeSi-93
Sep 21, 2001 09:50 AM
