post if you have your fan constantly on
Re: (Sketch_hs)
I do too, well more or less. I have it wired up to a swtich, and spliced into my computer harness, fan switch. Wont' cause any harm other then wearing out your fan sooner.
Re: (coneheadsracing)
There are two wires on the fan, a power and a ground. Make sure you have the correct polarity or the fan will blow the wrong way, but put one wire to a good ground and for the power wire, run it directly to the in-car fuse box, and just use a spade connector to one of the open +12V ignition spots there (use a multimeter to test), that way it will be on whenever the car is running, HTH
rolledthatho
38
06-18-2015 01:43 PM
