Valve lash specs... with crower cams.
Old Jul 12, 2006 | 03:50 PM
slowteg550's Avatar
Default Valve lash specs... with crower cams.
I am going to call Crower tomorrow, but if I can find the answer tonight, it's one less thing I have to deal with tomorrow. I know 90% of you will say not to run crower cams, but they are already in the car and I'm running them. So, I don't need any opinions on that, only factual info regarding the question at hand
Crower 63411t-2 Cams
Crower Titanium Retainers
Skunk 2 dual valvesprings
Ferrea Stainless valves @ stock size
Anyone know the correct valve lash? I've heard a lot of people say stock with whatever cams you use, but I would think it would have to change some. ??? if anyone knows please chime in...
Old Jul 12, 2006 | 04:59 PM
non-VTEC's Avatar
Default Re: Valve lash specs... with crower cams. (slowteg550)
what does the cam spec card say to use?
Old Jul 12, 2006 | 06:33 PM
Lmgrcivic's Avatar
Default Re: Valve lash specs... with crower cams. (non-VTEC)
personally I would stay away from crower cams I just had a friend snap a set on the dyno
Old Jul 12, 2006 | 08:12 PM
TurboLaxx's Avatar
Crower makes good stuff. I have a set of crower cams in a box now for my future build. I would buy from them over skunk2 or OBX anyday. Yes Jun and Toda have nice stuff but i dont want to spend all that cash for that upgrade.
Old Jul 12, 2006 | 08:21 PM
ludesleep's Avatar
Default Re: (TurboLaxx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lmgrcivic &raquo;</TD></TR><TR><TD CLASS="quote">personally I would stay away from crower cams I just had a friend snap a set on the dyno </TD></TR></TABLE>
You damn yankee he just said he didnt care??
Anyways wait till tomorrow cause its possible its the same but your supposed to go by what the cam card says. Basically if you don't have it waite to talk to a Crower tech.
Old Jul 12, 2006 | 08:24 PM
slowteg550's Avatar
Default Re: (ludesleep)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesleep &raquo;</TD></TR><TR><TD CLASS="quote">
Anyways wait till tomorrow cause its possible its the same but your supposed to go by what the cam card says. Basically if you don't have it waite to talk to a Crower tech.</TD></TR></TABLE>
Yeah I don't have the cam card b/c they are used, and have like 5k miles on them... which makes me not worry about them snapping due to the poor castings they had a while back
Old Jul 12, 2006 | 09:11 PM
ludesleep's Avatar
Default Re: (slowteg550)
well not only that but alot of people dont realize you should have your cam journals line honed for new cams as if you were buying a new crank. You go bolting a straight precision machined shaft in multiple bores that are not concentric with each other...well the answer is hell yeah its gonna snap...
Old Jul 12, 2006 | 09:29 PM
slowteg550's Avatar
If that was the case, then wouldn't people who run used honda cams break them?
Old Jul 12, 2006 | 09:42 PM
rmcdaniels's Avatar
Cam clearances are .050-.089, that's huge. I've never heard of anybody having to get their cam journals line honed to stay in that range, not if they are using the cam caps that came with the head.
Old Jul 12, 2006 | 09:47 PM
rmcdaniels's Avatar
Default Re: (rmcdaniels)
And looking at the cam card for my Crower 63401T-2 cams, whick have the same specs as the 63411T-2 cams (on the VTEC lobe), my clearances are:
I - .006
E - .008
revhardallday
Nov 26, 2008 03:08 PM
EK-TanK978
Oct 29, 2005 10:13 AM
velocitytrends
Apr 29, 2004 04:01 PM
PainfulTeg
Sep 23, 2002 12:08 AM
