random check engine
Old Jul 13, 2006 | 07:16 PM
playahwitgame's Avatar
Default random check engine
well every now and then i get a random check engine light that xcomes out of nowhere. i think it comes up because i may be running a lttle bit lean since i have a boost leak. and well it comes on, but it goes off as soon as i turn on the car. i can only thinkg of it running rich. thats really it. i have a obd2-obd1 p72 with hondata. any1 ever had this?
Old Jul 13, 2006 | 07:23 PM
boosted k20's Avatar
Default Re: random check engine (playahwitgame)
do u have an O2 sensor? if u dont, then that could be the problem. even though u may have the O2 sensor disabled in HONDATA, the ecu still looks for a signal. a quick fix if to feed like a 1 volt signal into pin D14 to trick the ecu into see n a signal
Old Jul 13, 2006 | 07:49 PM
Default Re: random check engine (boosted k20)
i do have an o2. i beleive the o2 is only disabled for tuning.
Old Jul 14, 2006 | 08:46 AM
any1 else experience this?
Old Jul 15, 2006 | 05:04 PM
Old Jul 15, 2006 | 05:18 PM
Cramerox's Avatar
Try to read the code it throws out- then you will know whats going on.
Old Jul 15, 2006 | 05:51 PM
Default Re: random check engine (Cramerox)
it turns off when i turn off the car
Old Jul 15, 2006 | 08:44 PM
qfast817's Avatar
jump it when the cars on
Old Jul 15, 2006 | 11:35 PM
xxxmikenicexxx's Avatar
Default Re: random check engine (qfast817)
Even though the CEL is turning off when you turn off the car, it is still being stored in the ECU's memory. The only way to clear it for good is to pull the ECU fuse. Turn the ignition to "On," and jump the service connector. Your code will be there. Please do this and let us know what it is (If you dont know how to read codes or dont have a Helms, there are multiple posts on H-T that will help you out, just search), therefore we can help you out as we will have a place to start. I had the same problem on my car, it was an intermittent knock sensor code (I believe wiring), and I when I got tuned, I disabled knock and it of course went away. Just an example, could be something as simple as a bad connection or ground. Anyways, yeah get that code and well get you fixed
Old Jul 16, 2006 | 12:21 AM
turbotime's Avatar
dollars to donuts its a code 1 [o2 content]
Im getting the same CEL running my wb02 narrowband signal to my ecu o2 input....
Seems to always throw CEL code 1 randomly while coasting in gear, doesnt effect performance at all, just that annoying light- goes away when car is turned off and then back on...
Old Jul 16, 2006 | 12:52 AM
Default Re: (turbotime)
sounds like what mine will probably be. so if its code1, what can i do for it. im sure the o2 sensor is plugged in. some1 sid something about it being diabled but isnt that only for the tuning session??
Old Jul 16, 2006 | 03:45 AM
NJIN BUILDR's Avatar
Its a Hondata bug.Let me guess, that it happens on long decels.Hondata says that its fixed in the latest burner software.If you reburn the chip with the new software it will go away.I have yet to try this with my car yet so I can't promise it works.
Old Jul 16, 2006 | 04:25 AM
Boosted2K's Avatar
Default Re: random check engine (NJIN BUILDR)
bah, I get the same thing running Neptune. It seems to just pop up randomly for no reason, sometimes right after a hard boost pull, sometimes just driving in vaccum.
I have no O2 sensors and I've jumped the service connector, but no codes are ever present.
Hasn't done it lately, so maybe it's fixed, It doesn't bother me....seems like a bug in the program
Old Jul 16, 2006 | 11:39 AM
Default Re: random check engine (Boosted2K)
see it kinda does bother me. i dont know, i have spent alot of money doing this right and i just hate looking at that cel. i dont know, it just bothers the expletive out of me.
Old Jul 16, 2006 | 12:05 PM
Tactic$'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotime &raquo;</TD></TR><TR><TD CLASS="quote">while coasting in gear, doesnt effect performance at all, just that annoying light- goes away when car is turned off and then back on...</TD></TR></TABLE>
I'm having this exact problem right now.
My injectors seem to turn back on when it happens! I get a "lean" reading on the PLX, and the car will hover at say, 3500rpm. A blip of the throttle and things seem to return to normal. The CEL does not always come on when this happens.
Do you have this problem as well????
Old Jul 16, 2006 | 01:54 PM
Default Re: (Tactic$)
it just seems to come on maybe 15 minutes after im driving. usually pops on after a good bosted run, the while im coasting, itll pop on
vtecgod
Apr 2, 2009 06:44 PM
turbotime
Oct 10, 2006 11:28 AM
spooledhonda
Apr 29, 2006 08:50 PM
Koyoloeor
Oct 13, 2005 04:57 PM
VSM EXtasy
Feb 3, 2003 08:58 AM
