slight hesitation before revving
my h22 has a slight hesistation from when the throttle opens and when it revs. Would this be more likely my bin i have in my ECU or is it more liely my cam timing is off a tooth? Other than that runs fine.
sounds like a tune issue, your would know if you were off a tooth.
I would double check the timing but i would think its in the tune or you might have a slight vac leak....
my car hesitated/bucked at very very light throttle, swore it was the tune, ends up i have a big vac leak but only under boost; made a pressure tester for the system, found the leak, fixed it, no more hesitation!
thewrai6th
Jun 29, 2007 01:41 PM
JSIR
Mar 18, 2002 08:41 AM
