What size wastegate? b18c1 t3/04 .57 8PSI?
I've looked around and there all different sizes of wastegates on the market. What is the optimal size in millimeters for this application:
GSR engine
t3/04 turbo .57
6-8 PSI normal
if you need more info I'll post what I can.
GSR engine
t3/04 turbo .57
6-8 PSI normal
Re: What size wastegate? b18c1 t3/04 .57 8PSI? (1990hondaHF)
Larger wastegates are able to control lower boost levels better, smaller wastegates are able to control more boost pressure easy up to a certain amount. with 8 psi a 35 or 38mm should do just fine on your setup.
Ive got a 35mm on my buddies delsol with a t4/to4e-60 and it acuratly holds 9 psi on spring all day, never had any type or boost spike
