Did a compression test.... what is the problem for my numbers?
Old Jul 9, 2006 | 10:05 PM
H.A.R.T B18C1EG6's Avatar
Default Did a compression test.... what is the problem for my numbers?
Modified by H.A.R.T B18C1EG6 at 7:04 PM 7/10/2006
Old Jul 9, 2006 | 10:14 PM
SOHC_MShue's Avatar
Default Re: Did a compression test.... what is the problem for my numbers? (H.A.R.T B18C1EG6)
any smoking or burning oil? Looks like you got messed up pistons.
Old Jul 9, 2006 | 10:25 PM
SOHC_MShue's Avatar
what kinda smoke?
Old Jul 9, 2006 | 10:35 PM
SOHC_MShue's Avatar
i can almost bet its oil smoke. Lots of times it will look white, but actualy has a bluish tint. I've blown headgaskets before and never noticed compression loss. Also if you had a blown headgasket it would probably be 2 adjacent cylinders with low psi.
Old Jul 9, 2006 | 10:55 PM
komat's Avatar
180 is what i get with 9:1 compression
Old Jul 9, 2006 | 11:00 PM
komat's Avatar
do a leakdown
it will give you a better clue on what it is
Old Jul 10, 2006 | 07:53 AM
RyanEJ8's Avatar
Default Re: Did a compression test.... what is the problem for my numbers? (SOHC_MShue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">i can almost bet its oil smoke. Lots of times it will look white, but actualy has a bluish tint. I've blown headgaskets before and never noticed compression loss. Also if you had a blown headgasket it would probably be 2 adjacent cylinders with low psi.</TD></TR></TABLE>
Yeah I've never seen an engine loose compression with a blown headgasket either.
Old Jul 10, 2006 | 08:22 AM
96 GSR-T's Avatar
Default Re: Did a compression test.... what is the problem for my numbers? (komat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by komat &raquo;</TD></TR><TR><TD CLASS="quote">180 is what i get with 9:1 compression</TD></TR></TABLE>
Im at 190-195 with a 8.8:1. The problem could be anything, do a leakdown test to better determine whats going on.
vipokc
Feb 4, 2009 06:57 AM
JDMtype Eg6
Jul 14, 2007 02:31 AM
.David
Mar 27, 2005 09:05 PM
Froggin
Jan 4, 2005 05:22 AM
Ri5e
Feb 10, 2002 09:54 AM
