OBD1 Convervion Injector ?
I have a b16 and i am going turbo and converting to obd1. What type of injectors am i supposed to use? the saturated or ...? TIA
Also 550 good enough size for a gt28r and 14psi?
obd1 and newer on a civic use saturated injectors, you can run up to a 750, they dont make above 750's in sturated that i am aware of. the injector size comes down to your h.p. goal.
if you are using an obd1 ecu, use saturated injectors, untill you need to go larger then use p-h. but no you dont need a resistor box, right now.
surkitroller
Dec 29, 2009 12:58 PM
