head gasket blow off
Old Jul 15, 2006 | 06:46 AM
konio's Avatar
Default head gasket blow off
I have D16A9 turbo engine, 0.8 bar, 250HP. ubedata perfect tune, ARP head studs and my head gasket's just blow off. A lot o peple said that oem can hold 1 bar. What head gasket should i use? Where can i buy it?
Old Jul 15, 2006 | 06:48 AM
jaydem_ekizzle's Avatar
Dude ive got friends with 400whp+ bseries turboed cars. Using only OEM headgaskets. Are your headstuds torqued right? Make sure when you put a new on its a compleltyey clean surface. and if it continues check for machine'ing problems with deck/head.
Old Jul 15, 2006 | 07:44 AM
8200RPM's Avatar
local hippie
Default Re: head gasket blow off (konio)
have you ever machined your head/block?
just from personal experience i know this caused me issues with my turbo'd sohc.
blew hg w/stock studs, then i had the head resurfaced only thinking the block was ok . got arps and slapped it back on, blew another hg. i was just boosting 5lbs w/ an ihirhb5.
Old Jul 15, 2006 | 08:24 AM
konio's Avatar
head and blosk was resurfaced, ARP studs torched 100Nm. This OEM gasket is not all metal like others honda's. Honda does not make all steel gasket to this engine
Old Jul 15, 2006 | 08:10 PM
whats the material then?
Old Jul 15, 2006 | 09:54 PM
konio's Avatar
Default Re: (jaydem_ekizzle)
around cilinders is steel oring made by 2 sheets and between them there is that other material, not metal
rick_rabies
Apr 15, 2009 12:49 PM
jbs
11
May 25, 2005 11:17 AM
sporkcrx
Apr 8, 2004 09:03 PM
servion
Mar 7, 2003 08:35 PM
