Tuning
Old Jul 11, 2006 | 07:54 PM
AZNracerx1989's Avatar
Default Tuning
When tuning a 2001 integra LS, is an outboard MAP sensor needed? Will the stock throttle body mounted one work? Thank you
Old Jul 11, 2006 | 08:05 PM
BoOsTeD C1's Avatar
Well that all depends on how many psi you plan to run...If its over 10.65 psi you will need an outboard map sensor but if its under 10.65psi the stock map on the throttle body will do just fine.
Edit:thanks joseph.Davis for correcting me
Modified by BoOsTeD C1 at 3:13 PM 7/12/2006
Old Jul 11, 2006 | 10:10 PM
Oleg's Avatar
Default Re: Tuning (AZNracerx1989)
YES! I had the same thoughts at the beginning, but as more I was getting into my turbo project (and sa more and more money was spent), I realized that if you want youe car to be smooth and reliable- there is no shortcuts, the money has to be spent. The same goes for the pressure sensor, you will need this if you want your car to run right.
Old Jul 11, 2006 | 10:38 PM
Joseph Davis's Avatar
Default Re: (BoOsTeD C1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoOsTeD C1 &raquo;</TD></TR><TR><TD CLASS="quote">Well that all depends on how many psi you plan to run...If its over 10.65 psi you will need an outboard map sensor but if its under 10.65 psi the stock map on the throttle body will do just fine.</TD></TR></TABLE>
Fixed it for you.
Bartman201
Aug 30, 2005 03:12 PM
Raf
Feb 25, 2005 07:54 AM
JR Integra
Jan 23, 2004 08:48 PM
yellowmonkeyboy
Jul 13, 2003 10:25 PM
