ecu?
Old Jul 14, 2006 | 07:43 AM
Whiteintegra's Avatar
Default ecu?
whats the best ecu to chip and socket if you are boosting an LS (b18b1) integra. I hear that the p28's are the way to go. I don't get it though b/c the p28's are vtec ecus. Why not use a p72?
I also hear that crome works better with the p30 basemap for some reason? since im going with crome, should i try to get a chipped p30 instead of a p72 or am i safe with just sticking with the p30 base map and de-activating the hig cam/fuel settings?
Old Jul 14, 2006 | 07:57 AM
adseguy's Avatar
Default Re: ecu? (Whiteintegra)
You can use a whole lot of differnt ECUs...just a few off the top of my head:
p75
p72
p02
p28
Check out PGMFI.org for the full list in the wekipedia.
Crome works well on the P30 basemap because a lot of code is developed for the p30 code. It has nothing to do with which ECU you run. Like you said all you do with a VTEC ECU is disable the VTEC part and ignore the high cam fuel/ign.
If you have to buy an ECU anyways get a VTEC one since you can just turn off the VTEC feature and later on if you decide to go VTAK then you have a capable ECU. If you can get the non-VTEC ECU cheaper you can go that route too. It's your choice
Old Jul 14, 2006 | 01:00 PM
Default Re: ecu? (adseguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adseguy &raquo;</TD></TR><TR><TD CLASS="quote">You can use a whole lot of differnt ECUs...just a few off the top of my head:
p75
p72
p02
p28
If you have to buy an ECU anyways get a VTEC one since you can just turn off the VTEC feature and later on if you decide to go VTAK then you have a capable ECU. If you can get the non-VTEC ECU cheaper you can go that route too. It's your choice</TD></TR></TABLE>
got it!
Old Jul 14, 2006 | 04:05 PM
stockb18c's Avatar
just get a p28 works well IMO
Old Jul 14, 2006 | 05:16 PM
adseguy's Avatar
Default Re: (stockb18c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stockb18c &raquo;</TD></TR><TR><TD CLASS="quote">just get a p28 works well IMO</TD></TR></TABLE>
So do the other ones
mpls
Feb 2, 2009 01:31 PM
kihun_cha
Dec 8, 2005 10:38 PM
auto moto
Aug 10, 2004 12:30 PM
typeeg
May 27, 2004 08:45 PM
streetlvlhatch
Mar 17, 2004 05:50 PM
