GM 3 Bar wiring on 96 integra???
Help please,
I have a 96 integra ls that i put a turbonetics kit on it. Today I stripped of the piggy back crap that came with the kit and intalled my obd1 ecm, conversion harness, and 750cc injectors. the car ran decent at idle once I had the fuel map set up for the bigger injectors. I then decided to wire in my 3 bar map sensor. after witing in the sensor the car would start up then stall. I am concerned that I have damaged my ecm by wiring the map sensor incorectly. I used wiring instructions that i found on this site but then relized that they were for a obd1 vehicle harness. If any of you have the correct wiring info please help me out. If I plug the factory map sensor back in and use the chipped ecm the vehicle still starts then stalls, if I use the obd2 ecm the vehicle runs, but runs like crap due to the huge injectors. I hope i didnt damage the ecm.
Re: GM 3 Bar wiring on 96 integra??? (KRWTEK1)
Well after work today I double checked my wiring with an alldata diagram. My wires are hooked up as fallows, A-->GRN/WHT B-->RED/GRN C-->YEL/RED. As far as I am able to tell this is the correct wiring for a GM 3 Bar map sensor. I will write a base map that only will consist of two changes: rescalling the fuel map for my 750 cc injectors and the 3 Bar map sensor option. I wont be able to do this until the morning, do you guys have any other opinions of why my integra is starting then stalling?
spidermancivic
06-21-2005 10:25 PM
