running new grounds
Old Oct 24, 2006 | 05:37 PM
teefunk01's Avatar
Default running new grounds
what are you guys using for grounding kits on your FI car....my stock one is really old beat and corroded/rusted ....I see kits for like $200 (buddyclub, greedy, etc..) and then theres ebay kits for like $40 ....my questions is anyone have good experience with either? and what materials are they using...
Old Oct 24, 2006 | 05:51 PM
igo4bmx's Avatar
im gonna redo mine with 4-8 gauge cable and these
Old Oct 24, 2006 | 07:04 PM
siblues's Avatar
Default Re: (igo4bmx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igo4bmx &raquo;</TD></TR><TR><TD CLASS="quote">im gonna redo mine with 4-8 gauge cable and these
Those are very nice but i know they will run you more than 40 bucks and that is where I think the ebay kit is a good deal?I mean how can they mess up some wire and terminals right?
Old Oct 24, 2006 | 08:59 PM
pgmatt's Avatar
Default Re: (siblues)
Go to the parts store or stereo shop and get some wire and terminals.Wiring is not the place to cheap out and for 40-50 bucks you could do a good,clean solid job of it.If you are lazy or incapable of hooking up a ground cable then spend the money for a nice kit.
Old Oct 24, 2006 | 09:10 PM
siblues's Avatar
Default Re: (pgmatt)
I would say get a better kit.Those terminals are around ten bucks a piece and for some good stranded wire in a 8 gauge will run you about a dollar a foot.That would start adding up quick
Old Oct 24, 2006 | 09:59 PM
Blaze45's Avatar
Brrraaaap!
I just used some amp power wire on my car and got some of those gold terminal connectors for the batt and the starter. The car started easier, ran much smoother. Definetly worth the $25 I spent.
Old Oct 24, 2006 | 10:12 PM
j dizzle
Guest
Posts: n/a
Default Re: (Blaze45)
found some extra battery cable in the garage and bought like 6 copper terminals for like $5
there is no need for those kits
Old Oct 24, 2006 | 11:08 PM
IntegraTypeR's Avatar
Default Re: (j dizzle)
its a good thing i saw this cause am about to redo my grounds too, but wanted to check if these are the only areas to look into?
1- Alternator ground
2- starter ground
3- valve cover ground
4- thermostat ground
there could be others, but i think the above are the essential ones right?
Old Oct 24, 2006 | 11:10 PM
chasemyhonda's Avatar
B A N N E D
Default Re: running new grounds (teefunk01)
i would ground the head instead of the valve cover. Redo the Tranny Chassis ground with something nice. and some people even say do the intake manifold ground.
Old Oct 25, 2006 | 06:54 AM
teefunk01's Avatar
Default Re: running new grounds (blindingxenon)
is there such thing as too many grounds? I mean I could run a lot of extra grounds...but is there any cons? Definitely looking into this
Old Oct 25, 2006 | 06:56 AM
BlueSi2k's Avatar
I bought one of those ebay kits for $25 the other day. Should be getting it soon, ill let you know how it looks. I figure theres not really much they could mess up.
Old Oct 25, 2006 | 07:05 AM
aaronISthrowed's Avatar
Default Re: running new grounds (BlueSi2k)
I'm pretty sure theres no need to spend $200 on grounds unless they can suck you off every time you drive your car.
Old Oct 25, 2006 | 08:13 AM
scB20teg's Avatar
Default Re: running new grounds (aaronISthrowed)
You can do all the grounds for you car with 1/0 gauge wire (might as well go big) for about $20-40. It just depends on how much wire you need and if your going to use an inline fuse from your alternator to positive battery terminal. There should be no reason to buy a kit or spend more than $50. It's pretty simple dude.
Go here for info and pics... http://www.caraudio.com/forum/...52355
schuetts
Oct 25, 2007 05:16 PM
stackz
12
Sep 1, 2007 02:10 PM
FishyMan
Dec 26, 2006 01:01 PM
RideOrDie
Audio / Security / Video
39
Jan 8, 2005 07:24 PM
steve00si
Dec 1, 2004 03:26 PM
