need help getting to dyno
Old Oct 28, 2006 | 08:22 AM
2redstars's Avatar
Default need help getting to dyno
right now i am useing my old .bin to start my car and move it around. its a modded version of the BBKA .bin. but that uses 450cc inj. i need a .bin to get my car to the dyno about 40 miles away. so if anyone can help me out it would greatly appreciated. on the way there car WILL NOT see boost, and will be driven 45-55mph.
i have tried to make my own chip, but cant get it right.
obd1 p28, so chrome or uberdata, stock map, no knock sensor, no o2 sensor.(wideband getting hooked up with aem ems at shop).
my set up basics
b20/b16
precision low imp 550cc
turbonetics bb 60-1
you probably want to know why i dont just plug in the aem unit, well the car originally was a 00 civic dx, then mini-me with y8 head & intake, and wired vtec useing a vafc2. then converted to obd1, and tapped into the conversion harness to do the iacv fix and for vtec.
so for an extra $50 the shop said the would take all that out and put in my obd2b aem ems.
Modified by 2redstars at 3:29 PM 10/28/2006
Old Oct 28, 2006 | 01:45 PM
2redstars's Avatar
Default Re: need help getting to dyno (2redstars)
im not paying $150 for a tow.
Old Oct 28, 2006 | 02:00 PM
jeremydde's Avatar
So I'm assuming you want someone to make a bin for you to try out?
Old Oct 28, 2006 | 02:28 PM
2redstars's Avatar
yes, just something to get me from point A to point B.
Old Oct 28, 2006 | 03:02 PM
jeremydde's Avatar
Default Re: (2redstars)
Try this out:
http://members.shaw.ca/jeremydde/b20.bin
This is a crome bin:
-no o2
-no knock
-550cc injector
-NO VTEC
-stock map sensor
Test it out and make sure that it idles well. If not I may have to change the injector offset slightly to get it to idle. Also, I did add boost tables, but I retarded it quite a bit in case you accidentally hit those cells, and had the computer add 140% fuel up there. Use at your own risk.
Old Oct 28, 2006 | 03:07 PM
2redstars's Avatar
thank you, i will give it a try tomorrow.
Arturbo
Nov 5, 2004 07:01 AM
tvrsir
Aug 19, 2004 10:23 PM
