Anyone use this Perma-Cool 12" 2300cfm fan?
I was looking at fans and this one moves alot of air and I was wondering if anyone has used it.
http://store.summitracing.com/...w=sku
Product Line: Perma-Cool Standard Electric Fans
Fan Quantity: Single
Fan Diameter (in): 12.000 in.
Height (in): 13.750 in.
Width (in): 12.500 in.
Thickness (in): 2.750 in.
Maximum Fan CFM: 2,300 cfm
Number of Blades: 10 blades
Maximum Fan RPM: 3,000 rpm
Blade Material: Plastic
Blade Color: Black
Shroud Color: Black
Shroud Material: Plastic
Amp Draw: 6.00 amps
Quantity: Sold individually.
Notes: This is a reversible fan that can be used as a pusher or a puller.
Blade Color: Black
Shroud Color: Black
Amp Draw: 6.00 amps
Re: Anyone use this Perma-Cool 12" 2300cfm fan? (platinum00)
Cut and pasted from here:
https://honda-tech.com/zero...age=1
I wanted to bring this up to date to help a few others. At least I hope.
I too was having cooling issues or at least I didn't like the engine running 205 on water temp all the time nor did I like having to the put heat on in the summer.
My old setup consisted of a Autozone 12" fan that I got for like $50 but it wasn't helping at all. I found out it was rated at like 800cfm which simply isn't enough. So I did some looking around and found this fan from Permacool (smaller than the one Platinum used BUT I used it as a puller).
I figured this should be plenty for me. After driving it to the battle of the imports, I have determined it works extremely well. I use Neptune RTP and set the fan to kick on @ 175. The water temp gauge NEVER got above 190 so I may fiddle with neptune a little to bring that up maybe a little. Simple software change. I changed NOTHIGN else in the car at all.
All in all, I HIGHLY recommend this fan. It was worth every penny and I'm glad I ditched the other one. Oh and it is actually pretty quiet. I was surprised.
Here are some pics of comparison. And yes, it was a tight fit.
Underneath shot
Top shot.
Hope this helps others.
Underneath shot
Top shot.
KamalHonda
05-30-2018 12:50 PM
