Total seal piston ring review..........
Old Oct 22, 2006 | 05:12 PM
Mugencrxsir1's Avatar
Default Total seal piston ring review..........
Please post your experiences with total seal rings, I'm looking into weather it's worth the extra $50 over the stock SRP/JE piston rings. I've heard great things about this design, please post your experiences. thanks
Old Oct 22, 2006 | 05:41 PM
Jared's Avatar
The installs I've done they seat just as quickly as any other quality ring with proper hone and don't leak down any better.
Old Oct 22, 2006 | 05:45 PM
Default Re: (Jared)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jared &raquo;</TD></TR><TR><TD CLASS="quote">The installs I've done they seat just as quickly as any other quality ring with proper hone and don't leak down any better.</TD></TR></TABLE>
So in your opinion, it's not real worth the extra $50 over the regular moly rings from JE/SRP?
Old Oct 22, 2006 | 06:26 PM
earl's Avatar
Default Re: (Mugencrxsir1)
In the cases of CP or JE, I think you will have the best performance using the piston rings they supply you. A cheap ring would make their pistons perform poorly so I feel the rings they supply are quite good.
Old Oct 22, 2006 | 06:33 PM
Muckman's Avatar
Moderator in Chief
Default Re: Total seal piston ring review.......... (Mugencrxsir1)
Does anybody have experience with their gapless rings on a boosted motor?
Old Oct 22, 2006 | 06:39 PM
Jared's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugencrxsir1 &raquo;</TD></TR><TR><TD CLASS="quote">
So in your opinion, it's not real worth the extra $50 over the regular moly rings from JE/SRP? </TD></TR></TABLE>
exactly
Old Oct 22, 2006 | 09:45 PM
SOHCD16y8's Avatar
Used both The SRP rings and Total seal. Both seated fine and both had great leakdown numbers. Not worth the extra money IMO.
Old Oct 23, 2006 | 07:30 AM
Default Re: Total seal piston ring review.......... (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">Does anybody have experience with their gapless rings on a boosted motor?</TD></TR></TABLE>
That is what I was talking about.....I'm assuming no one is going to buy the regular total seal rings when they swear by there gapless rings. So from the reviews from above, it does'nt seem worth it.
Old Oct 23, 2006 | 10:28 AM
Thought you guys should see the email I recieved from http://www.raceeng.com ...
"you want the gapless top set ..... the gapless 2nd set burns oil
in stock !!!"
thanks
Bob
http://raceeng.com/p-5188-xc-g....aspx
Old Oct 23, 2006 | 04:32 PM
NJIN BUILDR's Avatar
There is no reason for gapless rings.I have never been happy with engines I have built with total seal gapless rings.What they do to the second ring to make it gapless impairs its ability to scrape the oil off the walls,which is its main function.
drumminforev
Dec 11, 2006 05:38 PM
TeStUdO
Mar 19, 2003 11:26 AM
non-VTEC
Sep 21, 2002 02:23 AM
