BAD TIMING
Old Oct 24, 2006 | 11:11 PM
blakacintegra's Avatar
Default BAD TIMING
im looking into turbo charging my gsr and found out my piston rings are shot and was told that i need to replace the pistion rings, bearings, and head gasket....i found a Low compression engine kit that includes 81mm pistons, NPR chrome rings, ACL rod bearings, MLS high performance head gasket, and valve cover gasket ...if i have to go in the motor to replace the rings and bearings should i do the whole thing? what do you think, def going turbo soon so would the low comression kit be worth it?
Old Oct 25, 2006 | 04:00 AM
NJIN BUILDR's Avatar
Default Re: BAD TIMING (blakacintegra)
Like has been said many times on here before.Go with Honda bearings,have the cylinders checked,you will be better off boring the cylinders to the next oversize (usually +.5mm).Most people also use the oem head gasket and rings.I'm not sure what "BAD TIMING" has to do with your question.
Old Oct 25, 2006 | 08:17 AM
i meant bad timing like i was just starting to buy my turbo pieces and now this happens, now i have to spend my money fixing this.
brnlxndr
21
Jun 12, 2012 11:29 AM
collinsvc15
Nov 20, 2010 05:55 AM
z6boost
Jan 16, 2009 04:56 AM
ek9tl
Jun 18, 2007 04:18 PM
3rdGteg
Sep 27, 2002 05:56 AM
