weird issue with boosted d16
Old Oct 27, 2006 | 11:51 AM
thomas@LPS's Avatar
Default weird issue with boosted d16
well i noticed that i have been burning a little oil lately so i figured that i probably should do a compression test and a leak down. i did the compression check first 205, 210, 210, 205 and my haynes manual says that 184 is standard. but the leak down was bad 20, 15, 15, 20. anybody know why this could be?? the only thing i could think of was cam timing might be a degree off. any suggestions? thanks
Old Oct 27, 2006 | 12:42 PM
igo4bmx's Avatar
are u doing a compression test with the car cold or warm?
Old Oct 27, 2006 | 01:20 PM
RyanEJ8's Avatar
Default Re: weird issue with boosted d16 (civic_ex_95)
Is the engine completely stock?
Old Oct 27, 2006 | 03:53 PM
thomas@LPS's Avatar
car was warm. yes with the exception arp head studs.
Old Oct 27, 2006 | 04:43 PM
igo4bmx's Avatar
Default Re: (civic_ex_95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_ex_95 &raquo;</TD></TR><TR><TD CLASS="quote">car was warm. yes with the exception arp head studs.</TD></TR></TABLE>
do compression test cold
Old Oct 27, 2006 | 05:55 PM
thomas@LPS's Avatar
Default Re: (igo4bmx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igo4bmx &raquo;</TD></TR><TR><TD CLASS="quote">
do compression test cold</TD></TR></TABLE>
why?
Old Oct 27, 2006 | 06:17 PM
SovXietday's Avatar
Everything expands when it's warm.
Old Oct 28, 2006 | 07:41 PM
thomas@LPS's Avatar
bump
Old Oct 30, 2006 | 02:15 PM
RyanEJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_ex_95 &raquo;</TD></TR><TR><TD CLASS="quote">bump</TD></TR></TABLE>
Did you do the test cold yet? or did you just ignore igo's advice?
Old Nov 1, 2006 | 10:31 PM
thomas@LPS's Avatar
Default Re: (RyanEJ8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanEJ8 &raquo;</TD></TR><TR><TD CLASS="quote">
Did you do the test cold yet? or did you just ignore igo's advice?</TD></TR></TABLE>
i dont need that kind of advice if your motor was made to run cold then i would to the test cold. but the motor runs warm. it just doesnt make sense? you have a piston ring gap for a reason. an explaination why i should do the test would help.
Old Nov 2, 2006 | 05:12 AM
RyanEJ8's Avatar
Yes, but the 184psi that your Haynes manual says is normal is tested cold.
Old Nov 2, 2006 | 05:33 AM
igo4bmx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_ex_95 &raquo;</TD></TR><TR><TD CLASS="quote">i dont need that kind of advice if your motor was made to run cold then i would to the test cold. but the motor runs warm. it just doesnt make sense? you have a piston ring gap for a reason. an explaination why i should do the test would help. </TD></TR></TABLE>
Paraphrase: "I'm gonna ask for help but not listen to anyone"
Old Nov 2, 2006 | 07:55 AM
snaileg's Avatar
lol
Old Nov 2, 2006 | 08:09 AM
95 hatch's Avatar
Default Re: (snaileg)
if your asking for help then why are you not listening
joey1320
Honda S2000
Feb 19, 2008 05:33 PM
alacard
Apr 26, 2007 12:11 PM
dbiker207
Nov 26, 2006 07:10 AM
Brad
Sep 8, 2006 02:13 PM
Chubz
Honda S2000
20
May 1, 2006 10:37 AM
