new dyno numbers finally
Old Oct 28, 2006 | 04:03 PM
turbotypeR@SPEC's Avatar
25 Year Member
Default new dyno numbers finally
made just shy of what i wanted.i think the thing holding it back the most is the gsr cams.it is falling off above 8500rpm.i have been planning on changing them for a while now,but have had to spend the money on more important things.anyway,at least i will get to race now.a little more work and it should do 750+
big thanks to ed senf for working it in and doing an excelent job as usual
and thanks ed for making me finally switch to hondata!
Modified by turbotypeR at 11:41 AM 10/29/2006
Old Oct 28, 2006 | 04:12 PM
A.E Motoring's Avatar
Default Re: new dyno numbers finally (turbotypeR)
Old Oct 28, 2006 | 04:18 PM
alpha's Avatar
Looks great. What turbo? What's the A/R on the turbine?
Old Oct 28, 2006 | 04:23 PM
25 Year Member
Default Re: new dyno numbers finally (0x64)
it is a t3/t71. .82 exhaust
Old Oct 28, 2006 | 04:39 PM
program's Avatar
what were you using before hondata?
Old Oct 28, 2006 | 04:45 PM
RedRCKT000's Avatar
Default Re: new dyno numbers finally (program)
nice numbers man
Old Oct 28, 2006 | 05:03 PM
1Quikgsr's Avatar
where is the money shot?
Old Oct 28, 2006 | 05:13 PM
Schister66's Avatar
Man U FTW
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote"> what were you using before Hondata?</TD></TR></TABLE>
i would also like to know
Old Oct 28, 2006 | 05:25 PM
b18sihatch's Avatar
big numbers
Old Oct 28, 2006 | 06:09 PM
JDM_EM1's Avatar
Default Re: new dyno numbers finally (b18sihatch)
very nice numbers, ed is great, he just tuned my car this week
Old Oct 28, 2006 | 06:11 PM
25 Year Member
Default Re: new dyno numbers finally (JDM_EM1)
i have been using the power fc.got the datalogit for it and it was taking too much time too get the different map sensor calibrated right.i gave up on it
Old Oct 28, 2006 | 06:12 PM
Arturbo's Avatar
Better than steak
25 Year Member
That is some power to get you into the 9's! I ran 10.1@147 in Denver with 630whp!
Old Oct 28, 2006 | 07:05 PM
TurboTegB18c's Avatar
Default Re: new dyno numbers finally (Arturbo)
Congrats on the #'s danny, hopefully we can put on a good show at IFO in Montgomery in a coulpe of weeks. Paul
Old Oct 28, 2006 | 09:13 PM
mrbsponge's Avatar
very sweet, hopefully i will see yall there
Old Oct 28, 2006 | 11:06 PM
BoostedJeff's Avatar
Default Re: (mrbsponge)
nice numbers
Old Oct 28, 2006 | 11:08 PM
paulzy's Avatar
Damn, with the new numbers and lighter chassis 9's should be no problem for you if you hook up bro. Any boost control?
Old Oct 29, 2006 | 01:14 AM
alpha's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotypeR &raquo;</TD></TR><TR><TD CLASS="quote">it is a t3/t71. .82 exhaust</TD></TR></TABLE>
Probably a mix of your cams and the T3 housing. Still a great powerband
Old Oct 29, 2006 | 01:51 AM
25 Year Member
Default Re: new dyno numbers finally (TurboTegB18c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboTegB18c &raquo;</TD></TR><TR><TD CLASS="quote">Congrats on the #'s danny, hopefully we can put on a good show at IFO in Montgomery in a coulpe of weeks. Paul</TD></TR></TABLE>
yeah, i hope so.i wanted a little more,but with the problems i have had this year,i am doing good to have it going.now we just need them to stay together
Old Oct 29, 2006 | 05:25 AM
maxpsi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboTegB18c &raquo;</TD></TR><TR><TD CLASS="quote"> hopefully we can put on a good show at IFO in Montgomery in a coulpe of weeks. Paul</TD></TR></TABLE>
I'll be you guys' backup driver. If you don't run good times, I'm pulling you out of the car and doing it myself. lol
Old Oct 29, 2006 | 06:34 AM
seen4ever's Avatar
Default Re: new dyno numbers finally (maxpsi)
how much boost? just wondering if you are running a 5bar map sensor or still on a 3bar
Old Oct 29, 2006 | 06:46 AM
SOHC_MShue's Avatar
Default Re: new dyno numbers finally (seen4ever)
Awesome numbers man
Old Oct 29, 2006 | 07:04 AM
g2turbo's Avatar
Default Re: new dyno numbers finally (SOHC_MShue)
Nice Danny, Im assuming you are using the S300? Have you setup the boost control using the HOndata or are you using something else?
Old Oct 29, 2006 | 07:41 AM
crucian's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotypeR &raquo;</TD></TR><TR><TD CLASS="quote">made just shy of what i wanted.i think the thing holding it back the most is the gsr cams.it is falling off above 8500rpm.i have been planning on changing them for a while now,but have had to spend the money on more important things.anyway,at least i will get to race now.a little more work and it should do 750+
</TD></TR></TABLE>Yup, I would say change the GSR cams. Good numbers. I only wish!
Old Oct 29, 2006 | 08:42 AM
25 Year Member
boost level was around 33-34psi.i am using an aem 3.5 bar sensor.i am using an s300 and using a turboxs boost controller
Old Oct 29, 2006 | 08:46 AM
Jared's Avatar
probably a mix of the cams and the hot side holding you back on the top end. congrats on the numbers.
