how big intercooler?
Old Oct 27, 2006 | 07:27 AM
gsr_pimp88's Avatar
Default how big intercooler?
how big of a intercooler would i need to get for my 01 gsr? i want to run aroun 8psi for around 250-70 WHP
Old Oct 27, 2006 | 08:05 AM
SynTeg's Avatar
Only 8 psi, run this one then
Old Oct 27, 2006 | 08:12 AM
b18sihatch's Avatar
Default Re: how big intercooler? (gsr_pimp88)
you dont need a huge intercooler for that much psi
Old Oct 27, 2006 | 08:17 AM
97gsrki's Avatar
Default Re: how big intercooler? (b18sihatch)
check out the small sized intercooler from precision turbo. You can jsut directly mount it to the bottom of bumper(not bumper cover obviously) and it is definetly good for the amount of power you are looking for.
Old Oct 27, 2006 | 08:33 AM
HNLV's Avatar
the bigger the better
Old Oct 27, 2006 | 08:59 AM
PickleTeg's Avatar
Default Re: (sqeezincheeser)
There is no reason to run a HUGE intercooler for 250-270 WHP. This is one of those cases where bigger is not always better. You can only cool the hot air so much. I don't know what size to tell you man, but you dont need the biggest one you can shove under your bumper.
Old Oct 27, 2006 | 09:10 AM
SynTeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18sihatch &raquo;</TD></TR><TR><TD CLASS="quote">you dont need a huge intercooler for that much psi</TD></TR></TABLE>Yeah you do. And most importantly it looks better.
Old Oct 27, 2006 | 09:31 AM
gsr_pimp88's Avatar
can i get some dimention ratings?
Old Oct 27, 2006 | 09:39 AM
b18sihatch's Avatar
Default Re: (gsr_pimp88)
i have a drag spearco intercooler that would be perfect for you
20x6x2 1/4 plus the end tanks
Old Oct 27, 2006 | 07:10 PM
gsr_pimp88's Avatar
bump
Old Oct 28, 2006 | 12:35 AM
95GSRTT
Guest
Posts: n/a
if you are only looking for a smaller amount of boost, either get a drag or rev hard intercooler. You do not need a big intercooler, the guys that are saying you do are ******* retarded. If you want to spend a bit more get a precision. All of those intercoolers should be pretty good upto 350 whp
Old Oct 28, 2006 | 04:03 AM
type B16's Avatar
i think you lose pressure running too big a intercooler for a low psi
Old Oct 28, 2006 | 05:37 AM
4thgenx42's Avatar
REV HARD, PRECISION, YONAKA, DRAG, INTERCOOLERS, WHICH ONE WOULD BE THE BETTER ONE. IM MAINLY TALKING ABOUT QUALITY.
Old Oct 28, 2006 | 05:40 AM
b18sihatch's Avatar
Default Re: (4thgenx42)
precision intercoolers are pretty goodout of all those
Old Oct 28, 2006 | 06:00 AM
BoostedB16EJ's Avatar
Default Re: (b18sihatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18sihatch &raquo;</TD></TR><TR><TD CLASS="quote">i think you lose pressure running too big a intercooler for a low psi </TD></TR></TABLE>
absolutely. by running too large an intercooler, you can actually cause a pressure drop ( usually in &lt;1psi). while it isnt a huge drop, on a low boost application it can make a difference.
granted a bigger intercooler will cool the charge temp more, what good does it do if its costing you power?
Old Oct 28, 2006 | 06:18 AM
b18sihatch's Avatar
Default Re: (BoostedB16EJ)
the same reason a bigger intercooler is better on larger psi setups is the same reason bigger intercoolers are good and bad on smaller psi setups
the larger the intercooler the more surface space the intercooler has to charge and cool down the air.
but on a smaller psi setup the larger intercooler is going to have a pressure drop because of the larger surface area..
thing is 1psi to xx degree drop might be worth it depending on how much cooler the air is before and after the larger intercooler
with high psi and larger intercoolers its the perfect situation becuase you are moving higher rates of air through the large intercooler cooling it effectivly
Old Oct 28, 2006 | 09:57 AM
95GSRTT
Guest
Posts: n/a
the problem with saying a larger intercooler will cool more effectively is too broad of a statement. You can only get as cold as ambient. So going too large would have absolutely no benefit.
Old Oct 28, 2006 | 10:12 AM
ryan89crx's Avatar
just get a 6-7" tall bar and plate ebay IC. they work fine and will support your hp goals easily
Old Oct 28, 2006 | 01:22 PM
gsr_pimp88's Avatar
which would be better for it, 2.5" or 3" piping?
Old Oct 28, 2006 | 02:49 PM
ryan89crx's Avatar
2.5"
Old Oct 28, 2006 | 03:21 PM
whiteef8's Avatar
Default Re: (ryan89crx)
if you know youre not going bigger any time soon (basically if youve already had a turbo car, and know you wont want anything bigger/better in a couple months) then i would recommend a 7-8'' Bar/Plate off of ebay, or johnnyracecar or something of the sort. Seriously tho, if youve never had a boosted car, let alone honda, then i would go with something a little bigger, like a precision 650 or something of the sort, because once you go boost, youll either want more and rebuild it, or blow it up, want more and rebuild it, haha. good luck
Old Oct 28, 2006 | 05:11 PM
Schister66's Avatar
Man U FTW
look for something like a JRC 6" or a CCA 6" or even a PTE 350hp
Old Oct 28, 2006 | 05:15 PM
b18sihatch's Avatar
you dont want a overkill on your setup. 3'' piping is way too big 2.5 is just fine, as you are only running 8psi you dont need a 25psi setup
smaller intercooler,smaller intercooler piping and you are good to go
Old Oct 28, 2006 | 06:38 PM
01geeser's Avatar
New User
i say he'll end up wanting more get the bigger one!
Old Oct 28, 2006 | 06:39 PM
gsr_pimp88's Avatar
still cant find anywhere to get it pretty cheap, any idea's?
