Cali 91oct what kind of power can I run
Old 10-26-2006, 01:35 PM
Boosteddb8's Avatar
Default Cali 91oct what kind of power can I run
Just curious what kind of power people are getting on crappy Cali 91oct gas, because this is my daily driver.
Im going to be running a LS block with crower rods, aries pistons, darton sleeves, with a gsr head with CTR cams and skunk2 valve train, HP raceing sheet metal intake manifold and bored out gsr TB, turbo set up a 57 trim t3/t4 turbonetics turbo, log manifold, tial WG, 550cc injectors and tuned with hondata s300.
What can I expect from this set up on 91oct.
Old 10-26-2006, 02:33 PM
Munkyw3rkz.webs.com
S@nt0s's Avatar
Default Re: Cali 91oct what kind of power can I run (Boosteddb8)
there are many cali cars making good power on our 91 oct..
i personally made 282 on a LS-T with 4 bent valves on 10psi..
my homies 84.5 LsVtec made 365whp on pump and ran 11.3 in a full weight GSR
Old 10-26-2006, 02:39 PM
riceball777's Avatar
with 91 octane and 9.1 compression most tuners sugest you boot about 1 bar or 14-15psi
i made 385wtp on 14 psi with a t3 60-1 and my friend make 430whp 14psi on a gt35r
it all depends on how big your turbo is. the bigger the turbo the more hp your going to make weither it be on pump gas or race gas
Old 10-26-2006, 02:58 PM
adseguy's Avatar
Default Re: Cali 91oct what kind of power can I run (riceball777)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceball777 &raquo;</TD></TR><TR><TD CLASS="quote">with 91 octane and 9.1 compression most tuners sugest you boot about 1 bar or 14-15psi
it all depends on how big your turbo is. the bigger the turbo the more hp your going to make weither it be on pump gas or race gas </TD></TR></TABLE>
uhhh......NO
Boost is not the factor here. It's torque. Stay at or under 300wtrq and you should be OK. If you want to go higher we've seen water/alchy injection do VERY well in helping prevent detonation.
gixxr7five0
11-22-2010 12:26 PM
blasterman
03-08-2009 09:18 PM
EARLdaSQUIRREL
11-06-2008 08:13 PM
GetawayInMoscow
06-17-2007 10:49 AM
Boosteddb8
04-07-2007 10:54 PM
Quick Reply: Cali 91oct what kind of power can I run
