Which heatrange do you run?
Old Oct 23, 2006 | 07:17 AM
mrx's Avatar
mrx
Default Which heatrange do you run?
Just as a general information:
Which heatrange do you run on how many boost / engine / whp level?
And maybe what type of plug do you run in your setup?
Best regards
Old Oct 23, 2006 | 07:31 AM
Mugencrxsir1's Avatar
Default Re: Which heatrange do you run? (mrx)
heat range of 7 is usually thought to be perfect for FI.
Possibly 8, but always depends on your HP/set-up.
Old Oct 23, 2006 | 08:12 AM
mrx's Avatar
mrx
Default Re: Which heatrange do you run? (Mugencrxsir1)
Yes, thats exactly why i'am asking which heatrange ppl run in general on which hp levels and on which engines.
Old Oct 23, 2006 | 08:35 AM
DaveF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrx &raquo;</TD></TR><TR><TD CLASS="quote">Just as a general information:
Best regards</TD></TR></TABLE>
1- autolite raceplug-3932
2- 40 max
3-800~
Old Oct 23, 2006 | 08:40 AM
JDogg's Avatar
Default Re: Which heatrange do you run? (dturbocivic)
for most stuff under 300hp i run a 7, if its 300-400 on pump gas or up to 500 on race gas i run 8, over 400 on pump or 500 on race gas i run a 9.. (those are NGK numbers btw)
but you have to make sure to read the plugs, some engines like a different heat range than others. on JRSC setups i run an 8.
its better to start too cold than too hot, if its too cold it will just foul out, if its too hot you risk melting things due to pre-ignition.
97grnrs
Dec 11, 2006 09:56 AM
riceball777
Jul 27, 2006 08:45 PM
Slammd Sol
Oct 2, 2004 09:02 PM
EG-6Ghost
Jun 23, 2004 08:10 PM
Jared
Jul 2, 2003 03:03 PM
