b20/vtec turbo
Old Oct 26, 2006 | 11:22 AM
o'malley_808's Avatar
Default b20/vtec turbo
Just had a quick question I know its been gone over time and time again but I cant seem to find a solid answer. If I put eagle rods, je low comp pistons, arp rod bolts, and arp head studs with a vtec head. How much boost can the engine handle running a Garret T3/T04 turbo? Is it better to run a block guard or will it just restrict cooling? If I get sleeves and they are bored to 85mm how much boost can I handle then? Just trying to decide as my blockguarded b20/vtec blew up on 12psi which is believed to be from a faulty water pump. Trying to decide whether to go b20/vtec or a ls/vtec and continue boosting.
Thanks
Old Oct 26, 2006 | 11:37 AM
nasteboyii's Avatar
Default Re: b20/vtec turbo (o'malley_808)
b20 sleeves are weak
ls sleeves are designed differnet have seem many 400-500 stock block (aftermarket rods/pistons) run on the street all the time, b20 sleeves brake on low 200s, thats my opinion.
i would stick to the LS its the better bet for you,
good luck
dan
Old Oct 26, 2006 | 12:37 PM
2redstars's Avatar
i have done quite alot of research into this as well. and havent found any solid answers. mostly just things being repeated from what others have read.
i am about to find out the limits of a stock b20b block. well, it has a block girdle, gsr pickup, oil pump, and water pump. with a b16 head that has skunk2 springs, and retainers, and gsr cams. tubular manifold, & turbonetics ballbearing 60-1. it will be tuned hopefully next weekend with aem ems. it will be a conservitive tune at first until i get my other block built. but once thats done, the boost will go up.....
Old Oct 26, 2006 | 06:29 PM
Does anyone have a sleeved b20 block? The cylinder walls would still be the same thickness but how much boost can you hold then? Or maybe a better question is what is an ideal bore size for boost or does it even matter once sleeved?
Thanks
Old Oct 27, 2006 | 03:26 AM
nasteboyii's Avatar
Default Re: (o'malley_808)
sleeves make a world of difference not only did they change design but also change material used in b20 (this is diff then all the other b series) which makes it weaker for boost. If you sleeve a b20, u would be good to thats the only issue with the b20, but if u only want to make 500 or less i would say LS stock sleeves, i made 500 all year, no problems with sleeves (stock sleeves/b16) just to give you an idea, but i will be building a sleeves ls/vtec sooner or later (whenever i just find the extra 5k or so)
good luck
d
PS i just sold my build b20 becuase i did not feel confident in the sleeves as well
Old Oct 27, 2006 | 06:16 AM
2redstars's Avatar
i was disputeing the hp numbers for a stock sleeved b20 block. we all know the sleeves have a bad design. but i havent found anyone who actually has pushed them to there limits on a great tune.
Old Oct 27, 2006 | 07:25 AM
scB20teg's Avatar
Default Re: (2redstars)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2redstars &raquo;</TD></TR><TR><TD CLASS="quote">i was disputeing the hp numbers for a stock sleeved b20 block. we all know the sleeves have a bad design. but i havent found anyone who actually has pushed them to there limits on a great tune. </TD></TR></TABLE>
Just because somebody else pushed theirs to X amount of power doesn't mean that's the limit for everybody's B20. It's also not going to change the horrible sleeve design. My B20 lasted for a while, but I finally cracked the sleeves, wasn't really suprised, at least it was fun while it lasted. Time for the new setup!
Old Oct 29, 2006 | 01:01 PM
JDMFreak's Avatar
Default Re: (scB20teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scB20teg &raquo;</TD></TR><TR><TD CLASS="quote">
Just because somebody else pushed theirs to X amount of power doesn't mean that's the limit for everybody's B20. It's also not going to change the horrible sleeve design. My B20 lasted for a while, but I finally cracked the sleeves, wasn't really suprised, at least it was fun while it lasted. Time for the new setup!</TD></TR></TABLE>
I am curious, what kind of torture did your b20 go thru before she goes? I Currently have mine for 2 yrs. and it my daily driver, and I rev it up 6grand almost every day for fun driving...I love the tq. That the engine produces and power at all rpms...but I am very conservative with the motor.
Old Oct 29, 2006 | 01:08 PM
ATYPR's Avatar
go ls/vtec
perseverance
Jul 2, 2010 10:48 AM
B16CRXT
Aug 9, 2006 05:31 PM
tmramsburg
17
Jan 7, 2006 11:11 AM
ThefirstPACT
Nov 15, 2004 11:18 AM
