Oil feed relocation question..
Old Oct 24, 2006 | 05:31 AM
HighRevn's Avatar
Default Oil feed relocation question..
Is it ok to run -4an line to the fitting on the firewall then a -3an to my turbo? I can only get a 1/8bspt to -4an fitting for go into the oil sending unit hole. Or should I just run -4a tp the firewall and to the turbo
Old Oct 24, 2006 | 05:49 AM
BoostedEG6's Avatar
Default Re: Oil feed relocation question.. (HighRevn)
http://store.summitracing.com/...w=sku
I don’t know if that’s what you’re looking for or not? I would recommend running a 3an all the way.... if you run a 4an you will need an oil restrictor
Old Oct 24, 2006 | 06:27 AM
HighRevn's Avatar
Default Re: Oil feed relocation question.. (BoostedEG6)
Im getting everything from a local hyrdaulic supply place this is why Im asking , and I need bspt to an
Old Oct 24, 2006 | 06:31 AM
mike1114's Avatar
yes you can go from -4an from block to -3an to turbo.
I would suggest using a restrictor as well, even on the -3an feed line, I am.
You can get a restrictor used, buy one from like atpturbo.com or make your own.
Old Oct 24, 2006 | 07:18 AM
HighRevn's Avatar
Default Re: Oil feed relocation question.. (mike1114)
It wont have too much pressure? Precision told me not to run a restrictor....what should I do?
94preluder3084
Jun 8, 2007 09:46 AM
MotorMouth
Mar 20, 2006 07:12 PM
Dragline
Nov 13, 2004 06:00 PM
mattcalica
Aug 16, 2003 06:20 AM
b18cya
Feb 19, 2003 10:50 PM
