I need help sorting out the final details....turbo GSR
Man U FTW
I have a 1999 Acura Integra GSR and it is turboed right now. I am in the process of building a new setup for it, but i'm not sure how hard i should/can push it on stock. This car is going to be a daily driver, but next winter, the bottom end is going to be built. I need to decide on a realistic power goal that will hopefully allow this engine (65k miles and even compression) to last another summer.
Setup:
CoreyR Topmount manifold
3" dp and exhaust
Garrett T3/60-1 .63ar
Tial 38mm WG
Tial 50mm bov
2.5" charge piping
JRC 8" IC
RC550 injectors
Tuned on Crome by DB Performance in Rogers, MN
--my last setup made 275whp/194wtq on 9psi...what do you guys think i can make?? And what wg spring should i start with?? I'm going to get a boost controller but i think w/ this turbo i might have slight boost creep problems.
What psi should i tune on and what power level should i hope for??
Setup:
3" dp and exhaust
Tial 38mm WG
Tial 50mm bov
2.5" charge piping
JRC 8" IC
RC550 injectors
Re: I need help sorting out the final details....turbo GSR (Schister66)
Man U FTW
Does anyone have this turbo on their stock engine GSR?? I'm hoping to push 350whp or so out of it....just wondering if anyone has a similar setup and numbers...or spool time?
Re: (Schister66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 »</TD></TR><TR><TD CLASS="quote">Does anyone have this turbo on their stock engine GSR?? I'm hoping to push 350whp or so out of it....just wondering if anyone has a similar setup and numbers...or spool time?</TD></TR></TABLE>
adam my CRX has a JDM GSR in it and im looking to make 350whp stock block also but im going to be running sunoco 112 all the time. 60-1 will be a little laggy but they make nice power.
josh made 319 @ 10 psi on 93 on a stock GSR with a SC61 or a 60 trim, forget which.
Man U FTW
im hoping for 340-350whp on 92octane. I really wish they sold 93 up here or i'd tune on it for sure....
also Corey, i got my topmount and its beautiful
hondamonkey
08-15-2007 05:47 AM
DriveSlowHomie
06-30-2005 09:43 AM
