Golden Eagle studs?
Old Oct 26, 2006 | 06:35 PM
UNKNOWN_MEMBER's Avatar
Default Golden Eagle studs?
Who has experiences with golden eagle studs? i torqued them down to what it said on the instuctions that was included and i was having problems on the dyno. so i took the head out and noticed that the studs were loose?
Old Oct 26, 2006 | 06:40 PM
urbansi's Avatar
Default Re: Golden Eagle studs? (UNKNOWN_MEMBER)
I have done a set of arp's on a couple of cars and when setting into the block arp recommends to only hand tighten them to the block then tighten to 72ft/lbs... there is no reason that they should have been loose unless something was overlooked.
Old Oct 26, 2006 | 06:44 PM
Default Re: Golden Eagle studs? (urbansi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by urbansi &raquo;</TD></TR><TR><TD CLASS="quote">I have done a set of arp's on a couple of cars and when setting into the block arp recommends to only hand tighten them to the block then tighten to 72ft/lbs... there is no reason that they should have been loose unless something was overlooked.</TD></TR></TABLE> u know what i take that back, i beleive it was less than 15lbs torque on the block. edit: if someone has the specs to what to torque it to can u please post it here, i can't seem to find the instructions it came with.
Modified by UNKNOWN_MEMBER at 7:56 PM 10/26/2006
Old Oct 26, 2006 | 07:39 PM
someone! anyone!
Old Oct 27, 2006 | 01:57 AM
Old Oct 27, 2006 | 02:44 AM
DaveF's Avatar
i belive its 10ft/lbs torque to the block...
ive heard in the past that you need to tighten them... put the engine through a few heat cycles, then re-tighten.
Old Oct 27, 2006 | 02:46 AM
BoostedEG6's Avatar
Default Re: Golden Eagle studs? (dturbocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">put the engine through a few heat cycles, then re-tighten. </TD></TR></TABLE>
Old Oct 27, 2006 | 06:58 AM
matt k's Avatar
Default Re: Golden Eagle studs? (BoostedEG6)
snug them in the block you do not need a torque wrench then torq the head on let it sit for a few hours come back re torque the head the centers will be loose wait a little while do over every thing should be good if not repeat until all the studs click in on the first pull 75lbs with molly is pleanty sometimes when you loosen them the stud lossens that is normall
Old Oct 27, 2006 | 03:07 PM
Jared's Avatar
also did you use the headgasket crush method that comes with the instructions of the GE?
Old Oct 27, 2006 | 06:11 PM
Default Re: (Jared)
i don't recall any headgasket crushing method. i did torque the head down to 75lbs back it off half way then repeat that 3times...
Old Oct 27, 2006 | 07:11 PM
USDM 4G VTEC's Avatar
i put my studs by HAND per the ARP instructions
i torques my head in 2 steps as in any Honda manual
and i have never had an issue with loose bolts, and or bad headgaskets
do it right the first time and there shall be no problems
Old Oct 27, 2006 | 07:20 PM
Jared's Avatar
Default Re: (UNKNOWN_MEMBER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UNKNOWN_MEMBER &raquo;</TD></TR><TR><TD CLASS="quote">i don't recall any headgasket crushing method. i did torque the head down to 75lbs back it off half way then repeat that 3times...</TD></TR></TABLE>
exactly
Old Oct 27, 2006 | 07:27 PM
NJIN BUILDR's Avatar
Default Re: (USDM 4G VTEC)
The GE studs have a bullet nose that bottoms in the block.The ARP bottom at the ends of the threads.I also hand tighten the ARP studs but the GE studs torque in.Either way the studs shouldn't loosen up.Break-away torque is a lot less than tightening torque.A stud torqued to 75#'s w/moly lube may only take 50#'s to loosen.
Old Oct 27, 2006 | 07:37 PM
Jared's Avatar
Default Re: (NJIN BUILDR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR &raquo;</TD></TR><TR><TD CLASS="quote">The GE studs have a bullet nose that bottoms in the block.The ARP bottom at the ends of the threads.I also hand tighten the ARP studs but the GE studs torque in.Either way the studs shouldn't loosen up.Break-away torque is a lot less than tightening torque.A stud torqued to 75#'s w/moly lube may only take 50#'s to loosen.</TD></TR></TABLE>
agreed. also, when you loosed the nuts, occasionally the studs will loosen with them. is that what you experienced?
Old Oct 27, 2006 | 08:12 PM
Default Re: (Jared)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jared &raquo;</TD></TR><TR><TD CLASS="quote">
agreed. also, when you loosed the nuts, occasionally the studs will loosen with them. is that what you experienced?</TD></TR></TABLE>
Yes,but I don't think its a problem.I have seen the studs locktited in before.It is ok to do this as long as the nuts are torqued before the locktite sets up.This is not the way i prefer to do studs tho.
slowboy90
Nov 19, 2010 02:30 PM
jspeedy
Nov 4, 2008 03:45 PM
kuja396
28
Aug 1, 2008 10:25 AM
skiracer8148
17
Apr 1, 2007 09:17 PM
V8whaaa
Oct 7, 2006 09:13 AM
