Rc injectors , can i use these sl4-750 on GSR , please look
* B A N N E D *
I have a set of RC 750 injectors SL4-750 to be exact . Now these dont wanna goto into my gsr fuel rail in a nice way at all . I see posts of poeple using them and then some that can't . I saw some say these are for k series engines. Can i make these work or should i sell and get maybe sl9's? which i have seen around being advertised for b/d series engine?
Re: Rc injectors , can i use these sl4-750 on GSR , please look (crxsiperf)
are they not going into the manifold and fuel rail, if so this is what you doing wrong, dont put the o ring on the injector, put it into the manifold, line up all 4 injectors to manifold and fuel rail then slowly tighten the fuel rail down, i had the same problem on a b16 with the RC SL4-750's thats how rc said said to do it, also if the injector plugs dont want to fit, trim the little black nipple inside the injector, not much at all, mine was obd1 works perfect no leaks, no problem.
SolAssassin
11-23-2009 03:20 PM
