high boost flutter / cant hold high boost issue
Old Oct 22, 2006 | 05:57 PM
liam821's Avatar
25 Year Member
Default high boost flutter / cant hold high boost issue
When the boost is set at over 25psi or so i get a flutter sound and the boost gauge starts jumper all over the place (up and down about 5psi). It sounds like the turbo is surging. I was thinking my wastegate isnt large enough to hold the boost pressure. I only have an old school tial 35mm with a .7bar spring. Could that be the issue? It holds fine at 20psi but after that i start getting this issue.
I dont think i have any vacuum leaks that i know of, however i need to get a new wastegate gasket as mine is leaking a little.
setup:
tial 35mm .7bar spring
apex'i avc-d boost controller
garrett gt3082r turbo with s-cover & .63ar exhaust
afi ramhorn manifold
neptune rtp with 880cc injectors
thanks,
liam
Old Oct 22, 2006 | 06:10 PM
y7turbo's Avatar
Default Re: high boost flutter / cant hold high boost issue (liam821)
maybe the blow off valve isnt holding the pressure
Old Oct 22, 2006 | 08:21 PM
liam821's Avatar
25 Year Member
Default Re: high boost flutter / cant hold high boost issue (y7turbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by y7turbo &raquo;</TD></TR><TR><TD CLASS="quote">maybe the blow off valve isnt holding the pressure</TD></TR></TABLE>
I have a tial 50mm bov with a 1bar spring in it. So i wouldnt think that would be it.
liam
Old Oct 22, 2006 | 09:49 PM
SOHC_MShue's Avatar
have you tried a larger wastegate spring?
Old Oct 22, 2006 | 10:36 PM
vaporboy12's Avatar
Default Re: high boost flutter / cant hold high boost issue (SOHC_MShue)
yeah up the gate spring or if that doesnt work time for a bigger gate
Old Oct 23, 2006 | 07:31 AM
liam821's Avatar
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">have you tried a larger wastegate spring?</TD></TR></TABLE>
I havent, i suppose i can try it! Any other ideas?
Old Oct 23, 2006 | 08:07 AM
99B16Si's Avatar
put in a stiffer wastegate spring
Old Oct 23, 2006 | 03:55 PM
liam821's Avatar
25 Year Member
Default Re: (99B16Si)
I ordered a 1bar spring - ill let you all know if that fixes the problem!
liam
richboi
Apr 15, 2007 07:46 PM
igo4bmx
Aug 4, 2006 06:53 AM
avsrule414
Dec 10, 2005 09:07 AM
japspec
Oct 24, 2003 07:49 PM
Etylorcen
Jun 4, 2002 11:50 AM
