zc with turbo any one please help thanks
when i warm up my car and drive it for a while it runs fine without hasitation and after about 30-40 min of driving it once i start boosting again it hasitates like almost like choking . My fuel pressure regulator read 50psi and if i give gas it reads 52-55 psi and i am only running like 5 lbs of boost. What do i need to do to enjoy my ride. The fuel pump has been replaced, injectors are 310cc, throttle body i cleaned it with carb/choke cleaner from pepboys, iacv took it off and cleaned it with carb choke cleaner i let it dry and put it back on, changed the fuel filter, cap and rotor................. and now i am just out of ideas its a ZC MOTOR VTEC WITH XS TURBO KIT THANKS
Whats the idle psi pressure that it is suppose to be on fuel pressure regulator thanks
