stock valves ok for 400whp?
Building a LS for boost. Just wanted to know if my stock valves are ok for 400whp on pump gas.
upgrading to crower dual valve springs, crower steel retainers, and 402-t. Should i get valves too? im only gonna go for 400whp.
im asking because i dont wanna upgrade something that i dont need to. Its also gonna be my daily driver, if that matters.
Re: stock valves ok for 400whp? (komat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by komat »</TD></TR><TR><TD CLASS="quote">as long you dont dump the clutch you be fine. preload if you are launching it.</TD></TR></TABLE>
Just curious, what does that have to do with the valves?
Re: stock valves ok for 400whp? (LeGeND4LiFe)
opps i thought you said axels
but i asked earl about this when i was doing my setup. he said it be fine at that power level.
cool thnx.
cool thnx.
Location: Home Of The Players And PIMPS, IN, united states
Re: stock valves ok for 400whp? (tdo)
OEM type-R valves are the best. Stock valves in general are good till A LOT of hp over 400whp. Tune it correctly and youll never have a problem.
Guest
Posts: n/a
Re: stock valves ok for 400whp? (Boosted2K)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted2K »</TD></TR><TR><TD CLASS="quote">stock valves here
See my sig for numbers</TD></TR></TABLE>
me too. must be the tuner
Re: (adseguy)
Thnx everyone.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adseguy »</TD></TR><TR><TD CLASS="quote">I have some supertech valves for REAL CHEAP if you want them. They are worth $175, but I'll give them to you for $50 if you want them</TD></TR></TABLE>
i dont wanna upgrade if i dont have to. thnx though.
ive never worried about valves and im looking to run over 400whp. and it does have alot to do with the tuning. ive never worried about tuning either cos im willing to shell out the cash to do everything right like most
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tdo »</TD></TR><TR><TD CLASS="quote">Building a LS for boost. Just wanted to know if my stock valves are ok for 400whp on pump gas.
im asking because i dont wanna upgrade something that i dont need to. Its also gonna be my daily driver, if that matters.</TD></TR></TABLE>
If you are upgrading your valve springs upgrade your valves. Stock valves with aftermarket springs occationally fatigue due to higher seat pressure. I know 2 cases where this type of fatigue has happened. In both cases the motor was destroyed.
There is no point skipping $200 and risking your whole motor.
drumminforev
10-05-2006 04:30 PM
drumminforev
13
10-05-2006 11:53 AM
