Can i boost my motor?
i have a 97 b18c spec r motor running 11.1-1 compression if i did like a copper head gasket, blockguard, and arp head studs ya think i would be ok for running 8 psi on a turbo or even a supercharged setup?
anything is possible. First do your research, and if you decide to boost make sure you go to a GOOD tuner. With a high compression motor, everything is in the tune!
Re: Can i boost my motor? (cyko4374)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cyko4374 »</TD></TR><TR><TD CLASS="quote">i have a 97 b18c spec r motor running 11.1-1 compression if i did like a copper head gasket, blockguard, and arp head studs ya think i would be ok for running 8 psi on a turbo or even a supercharged setup?</TD></TR></TABLE>
I'd say do a compression and leakdown test first.
IM 11.3 compression on my jdm itr, im at 6psi and did 12s on the 1/4 mile. Now i want to go faster. And i will be building the block sleeved 9:1 on like 25 psi. I said if i hit 12s im happy but guess what im not loll now i wanna go faster so its up to you.
Re: Can i boost my motor? (1Quikgsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1Quikgsr »</TD></TR><TR><TD CLASS="quote"> IM 11.3 compression on my jdm itr, im at 6psi and did 12s on the 1/4 mile. Now i want to go faster. And i will be building the block sleeved 9:1 on like 25 psi. I said if i hit 12s im happy but guess what im not loll now i wanna go faster so its up to you. </TD></TR></TABLE>
[ricky bobbie]I wanna go fast[/ricky bobbie]
hahahaha I know what you mean though.....
To the OP get a GOOD tuner and EMS and you will be fine, but you will want more down the road
GForceInteg
05-29-2003 10:15 PM
advanracing62
05-27-2003 05:51 PM
