running feedline w/o oil sensor, can i do it?
Re: running feedline w/o oil sensor, can i do it? (bmw626)
If you run without the sensor your "oil pressure low" warning light will never light. That's fine if you check your oil regularly.
Re: running feedline w/o oil sensor, can i do it? (beepy)
ok good now i can save myself a headache of taking my adapter off and seeing where the leak is coming from, i will just run the straight feedline, thx
nothing catasrophic will happen but I believe your low oil light will come on.
Honestly, the best thing to do is buy a sandwhich that goes on before the oil filter, it has ports on the side for gauges AND oil feed.
I have had many different setups, from tee'ing them all off of one location on the firewall to others and I think the sandwhich is the cleanest.
I got one that lets me run an external oil cooler also on my ride.
Doing it the way I said, you can leave the oil sensor on still too...
Re: running feedline w/o oil sensor, can i do it? (mike1114)
better to have it man,, ur oil pressure light won read right,, always check ur oil,, running turbo and that new motor u dont know how fast ur oil will burn if it does,, no oil= ruin turbin,, just trying to help but ur going to do what you want..
L8ER
L8ER
Re: running feedline w/o oil sensor, can i do it? (cwf1988)
cars done chad, running and all, i am gonna take a break in run to Statesville later maybe, depends on the weather. i already took a test run and its squirmy as hell
I don't run the oil pressure switch with my setup, but then again I check my oil regularly and have an oil pressure gauge. I've always heard it's a dummy light that doesn't come on until it's too late anyways.
tiannalind
02-28-2007 03:15 PM
