water spueing from back of block
Old 02-24-2010, 01:08 AM
hmt_eg's Avatar
Default water spueing from back of block
so about 2 months ago i went to start my car after we had sub freezing temps and forgot that i didnt have antifreeze in the system. water started spewing out of the driverside rear of the block and i thought i had destroyed my waterpump took it off and it was fine. my question is... is the block cracked somewhere that i cannot see or is there a plug ment to releive pressure if something like this were to happen? i ask this because many old school v8's have them and i dont want to swap in another block if just a plug have popped. any input is greatly appreciated!
Old 02-24-2010, 01:21 AM
zenney's Avatar
Default Re: water spueing from back of block
i think you should just replace all the tubeing i might have gotten really cold and cracked so double check on your tubeing
Old 02-24-2010, 01:24 AM
DCRB's Avatar
i agree with zenney. there's the water tube at the back of the block, along with several rubber hoses that run to the iacv and the fitv. my guess would be that maybe the return line to the water tube from the iacv popped on ya
Old 02-24-2010, 01:29 AM
hmt_eg's Avatar
right on thank you! i bought a b20 block just in case the worse has happened.
m.glisson003
12-15-2011 04:27 AM
integraboosted
10-13-2007 09:20 PM
youngkow
11-22-2003 08:38 PM
The_Head
02-26-2002 09:00 AM
Quick Reply: water spueing from back of block
