Wrenching Your EF
Wrenching Your EF
this is a rip off of "what did u do to your ef today" i loved that thread and ive been gone awile so imagine my suprise when it was closed so im trying to start it back up, lol, so what did u do to your ef?
Re: wrenching your ef
ok so the rocker is on and i have pics but my stupid usb reader for my micro sd is jacked up so it will have to wait until i get home to post pics.....it was a hell of alot more fabrication than i though i was gonna have to do
ok so here are the pics as promised...
what i started with...a rust hole big enough to put my hand through
By tearsdmf at 2012-08-08
so lets grind off some paint and open up the hole to see what were dealing with...
well i see ive got alot of bondo
but even worse is this ...big bump =car in two pieces?
alright now that we know what were dealing with time to get to work
so after cutting out this section of the rocker we can see how deep the rust actually goes
and more importantly what needs replaced!
hey who stole my rust?
at this point i decided to reinforce the inner panel with a 30"x4.5" piece of 18ga. mild steel spot welded in the middle and seam welded at the edges...this is my buddy doing a little welding so i could get an action photo
a little quick fab work with some 20ga. and ive got a replacement for the inner structure
but before it goes on its time for some weld through primer and some self etching where it wont be welded
the new subframe support welded in place i also had to make a piece for the lower wheel arch to be welded to as it was also rotten
a lttle more self etching primer and now its time to close her back up
so now all thats left is finish welding and then body work .....not too bad for my first time doing structural rust repair ...what do yyou guys think?
took out my axles and put in my new trans. found out i have a bad joint on my driverside axle so i need to go get a new one of those. hopefully car should be running in a day or so
that was the worst spot on the body thankfully ....thats why it was adressed first...and yes they salt in columbus and it sucks... this car serves year round and im glad i could repay her... im slowly bulletproofing her to be a track car with a full interior and a cage... but something that could show up at a car show and turn a few heads....its not a show car its just a car that shows up
went to the junkyard and got the hardware i needed for my stock front sway bar and installed it also picked up a spare main relay and key less door handles
haven't been doin much to the ef, been workin on tearin apart my accord's motor for a rebuild. buuuuuuuut i topped off its oil and put gas in it. still getting a consistant 250 miles to 30 bux of v power regardless of me smashing vtakz to redline in every gear or me babying and shifting at 3k rpms
Hey guys.
I'm new here and I've been lurking for a while but I figured I'd start posting.
I've currently got a donor 91 Si hatch shell that I'm pulling parts off of to put on my 91 dx hatch. Today I pulled the exhaust, rear DC tie bar, and front stock swaybar off the donor.
I installed the front Si sway on my dx (which didn't come with one), set the exhaust aside for later, and cleaned up the tie bar to sell for a few bucks. I'm running a Progress 22mm rear sway, so that tie bar is useless to me.
I've still got coilovers and wheels to pull from the donor, as well as the harness. I've got a D16z6 and 5spd tranny to swap into my dx, just pulling parts together and getting ready. I'm pretty much a Honda newb, so I'm taking things slow and doing a ton of reading on here.
Went to change the clutch and throwout bearing but the company that sold me the kit gave me the wrong stuff... pooooo
http://www.facebook.com/?ref=logo#!/...type=1&theater
bumpin this up! lol decided to scrap my accord, picked up a soon to be new daily, 97 passat wagon glx vr6 blah blah blah lol.
any ways scored some tl replica projectors from a buddy of mine, going to see if i can't swap them into a set of matrix racing projector housing head lights that i have. if not then i'll buy some zc head lights, and do a proper retrofit into those housings.
planning on tearing down my hatch this winter. needs new bushings in the rear bad, and i want to bore out my block and get some eagle rods in there so i can boost safely. also need to replace my 2nd gear shift fork and r&r my transmission
caught up on orders, on a week vacation from work. i think its time to install this:
http://youtu.be/CYAh5dZLx5A
