89 crx dx - b16a1 wiring conversion??
hey, i'm really trying to save some cash and rewire my crx dx wiring harness into a wiring harness for a b16a1. I need to know if anybody knows a website or place where i can get a diagram of how to convert. Please help
thanx
jim
thanx
jim
Location: I told you to wait in the truck in Texas, United States
Re: 89 crx dx - b16a1 wiring conversion?? (2ndGenREX)
I did it using the following sites:
http://www.geocities.com/c_rexboy/mpfi.html
OR
http://www.geocities.com/teampimports/fuelinj.html
And
http://tjshondas.20m.com/b16awire.html
OR
And
Re: (2ndGenREX)
1. You will need to convert to DPFI to MPFI!!!
2. Then you will need to convert to DX TO SIR OBD1.
3. You will have to run all the wires from the ECU to the Engine harness modify wires cut wires all the good ****.
If someone can do the wire harness for you that would help a lot. Wiring will be the hardest part off the swap if done right your engine should start up fine if everything is in working order when engine is put in the DX.
It is not that hard once the wiring is done. If you have any problems post here maybe I can help you out...
