obd0 dohc zc vs. obd1 dohc zc??
I am in the process of swapping in a obd1 zc into my 91 crx si and have some concerns: are there part differences from the 88-91 dohc zc's compared to the newer ones? for example i was reading that people use 89 integra plug wires on the obd0 zc's... is this the same for the obd1's. Is everything else the same because i have found lots of part lists for the non-obd's but not the others, what about cam specs???
any help appreciated? i've been searching thanks
Re: obd0 dohc zc vs. obd1 dohc zc?? (jdm169)
i would have went with the OBDO motor in your OBDO car...IMO.
i think there are several differences in the OBDO ZC and the OBD1 ZC.
im not too sure on the subject but i gave it my best.
Good Luck
Good Luck
Re: obd0 dohc zc vs. obd1 dohc zc?? (Touge Panda)
You need to start going to http://www.thezcresource.com/ for your ZC needs. The OBD1 ZC subject has quite a few long threads there.
Re: obd0 dohc zc vs. obd1 dohc zc?? (azulito)
the fuel and ignitin system is based off the z6 motor.........same plug wires from an 88-89 teg but due to the diff dizzy its a tight fit......
thats basically all the diff..internals are the same... I have an OBD1 ZC in my 92 hatch...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Touge Panda »</TD></TR><TR><TD CLASS="quote">i would have went with the OBDO motor in your OBDO car...IMO.
Good Luck </TD></TR></TABLE>
yeah i understand your point but i got the motor for really cheap and couldn't pass it up... it's all good i finished the swap and the motor runs great, i'm just looking for more info on the motor and differences
i've checked out the zc page it has some good stuff thanks
anyone else have some info thanks again
