cluster problems..
senior gold member
cluster problems..
my buddy has an 89 crx si. his tach, fuel, temp gauge doesn't work. some of his warning lights don't work either. we tried a different cluster and the same thing happened. could it be a short? I checked the connections and everything seemed fine. anybody have any ideas?
Re: cluster problems.. (Ivan)
Maybe a loose ground? The ground for the dash harness is on the steering column check that out and see if its loose or anything.
i had the same problem in mine. the 2 plugs that go in the fuse panel r identical. reverse them and see what happens. mine is a 91 tho the panel r different but worth a shot.
