auto to manual swap.. already searched
i have a crx DX auto, and i want to convert to a manual, can i use a manual tranny from a Si, what other parts do i need to buy (tranny, ecu, clutch assembly etc.)
thanks for any info.
Re: auto to manual swap.. already searched (doh boy)
Yes you can use an si trans. Here is the part list
trans
manual ecu
flywheel
manual flywheel bolts
pedals
And I'm not sure but you might need a manual trans mount. And a new starter for a manual trans to. I have done it before so if you have any more questions IM me.
trans
manual ecu
flywheel
pedals
Location: Land of the free, whoever told you that is your enemy
Re: auto to manual swap.. already searched (90blackcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx »</TD></TR><TR><TD CLASS="quote">Yes you can use an si trans. Here is the part list
trans
manual ecu
flywheel
pedals
And I'm not sure but you might need a manual trans mount. And a new starter for a manual trans to. I have done it before so if you have any more questions IM me.</TD></TR></TABLE>
Like he said and then.....
Manual front X-member
Manual Mounts all except driver's side required
Clutch cable and mounts
Manual Shift linkage..............
That should kill it then, killer!
trans
manual ecu
flywheel
pedals
1 Post
If you're keepin the D15 and the DPFI
The PM5 ECU WILL WORK. It will however throw a code for the lockup solenoid. But it WILL run the D15 correctly.
Or look for a PM5 from a manual CRX or civic in a junkyard.
HTH
HTH
Re: auto to manual swap.. already searched (CRXBart)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXBart »</TD></TR><TR><TD CLASS="quote">
That should kill it then, killer!</TD></TR></TABLE>
I just got doing this and I used my same front x-member. Also the only mounts you need are the passenger side tranny mount and the rear mount the front and the drivers side are the same.
Re: auto to manual swap.. already searched (Vinceg99)
Really thats weird we had to swap the entire front xmember on my friends car. Mabey it was because it is an '88. Who knows. I couldn't beleive it myself when we had to change it.
rice a roni
23
09-30-2022 02:12 AM
