1991 prelude seats into 1990 CRX Si?
I've done some searching...and can't find anything along these lines and frankly don't have the time to beat off doing so.
I haven't had the time to put some mint 1991 Prelude Si seats into my CRX...just wondering if anyone has tried the trick. Just looking for any tips of if it is just too difficult due to track widths, mounting points etc.
Modified by Therapy at 5:55 PM 5/28/2004
Re: 1991 prelude seats into 1990 CRX Si? (Therapy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Therapy »</TD></TR><TR><TD CLASS="quote">So you've done it? Good to go if I do what ya said then...</TD></TR></TABLE>
Haven't done it, but that's how it can be done.
i dont think its as easy as vap says. i think theres gonna need to be some custom modification. for example, should he use the crx rails or the prelude rails? i think some drilling and fab work is gonna need to be done.
oh and good luck and be sure to post some pics whenever youre done.
Re: 1991 prelude seats into 1990 CRX Si? (5litereater)
they have very nice seats. it would be much improvment over the stock ones if you can fit the prelude rails in there. might be a bit large?
My bud and I pulled one of the REX seats and did a comparison. The prelude seats rails are placed further apart and the bolt points on the rails are closer together.
The rails on the REX bolt sideways into L-brackets attached to the bottom of the seat plate.
The rails on the Prelude seats bolt sideways on one side in the rear into an L-bracket and then the front bolts sideways into the pan tucked under the side leg bolster.
So pretty much a bitch to do without some drilling/welding and what not.
Sucks...the pair of Lude seats I pulled are absolutely mint...and the fact you can adjust the upper side bolsters on the drivers side is just to cool and comfortable.
I'm not gonna quite...I figure something out and will post some photos when I get things figured out.
Ah...seat pan swapping will not work...bottom cushion on Prelude seats are much wider and now wear to wrap the back seat cushion cover to on the Rex under pan.
Re: 1991 prelude seats into 1990 CRX Si? (kyle h.)
Prelude seats fit in the REX perfectly...the trick is bolting them up. But I've got some ideas to over come my current obstacles.
what i did with teg seats was cut the feet off of ther ails and welded teh civic feet to the teg rail...worked beautifully
Re: 1991 prelude seats into 1990 CRX Si? (kylefakesi-r)
That's exactly what I was thinking of doing...I just have to deal with the width problem on the Prelude seats...but a little more fabrication and I think it can be done! Thanks!
model x
09-02-2006 01:40 PM
Therapy
04-19-2004 10:38 AM
