overheating on highway
d15 is over heating just at hiway speeds. driving around town stoplight to stoplight its fine. any ideas??
-spenc
-spenc
Re: overheating on highway (Lo-Buck EF)
Chek ur radiator cap. I had that prob too with ma EE9. My radiator cap was faulty. It released preshure before time. Wich would lead to all my coolant to flow into the overflow tank...and eventually out of it.
overflow tank was in check all day(i was at autocross and looking at it all day.) since it gets hot at speed, but not at low speed, it doesnt seem like a water issue. im thinking cloged cat?
-spenc
-spenc
Re: (Lo-Buck EF)
do thermostat and flush and fill your radiator. redline makes a product called water wetter that is supposed to help with overheating. if none of this works than it's probably the water pump.
Re: (mr. carpenter)
That water wetter stuff is good for short term applications, but from what I have read, its detrimental to your radiator when in use for long periods of time. hth
well, upon taking it appart for teh thermostat, we found that the previous person to work on the engine (not in my car) put the thermostat in backward. i installed the engine in november, so it wasnt warm enough for it to realy overheat. plus, the thermostat that was in tehre wasnt opening.
problem solved.
-spenc
problem solved.
-spenc
