dohc zc half shaft
dohc zc half shaft
what usdm half shaft can i order for the jdm dohc zc tranny, early integra maybe? also anyone know about how much they cost, and i would have to use 90-93 teg axles right? oh ya this is for an 88 crx
Re: dohc zc half shaft (hOnDadiCt)
i dont think the 90-93 intermediate shafts work on the dohc zc. The correct part would be a 86-89 dohc integra inter. shaft.
Taken from http://hybrid2.honda-perf.org/tech/zcsifdswap.html
Parts that you will need to make this work
ZC or 1990-93 Integra axles
ZC or 1986-89 Integra intermediate shaft
Re: dohc zc half shaft (90crxzcgasd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90crxzcgasd »</TD></TR><TR><TD CLASS="quote">i dont think the 90-93 intermediate shafts work on the dohc zc. The correct part would be a 86-89 dohc integra inter. shaft.
It's wrong, the integra 88-89 half shaft didn't ahve the same bolt pattern on the block
Re: dohc zc half shaft (4g4drb17)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4g4drb17 »</TD></TR><TR><TD CLASS="quote">so the 86 to 87 half shaft is the right one?</TD></TR></TABLE>
No, the ZC JDM half shaft could be easy find on ebay
Re: dohc zc half shaft (Garrett)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Garrett »</TD></TR><TR><TD CLASS="quote">
No, the ZC JDM half shaft could be easy find on ebay </TD></TR></TABLE>
you know i thought that the zc was the only one that fits but its been like 6 years since ive owned a zc. When i saw that site i thought it was wrong but went with what they said. thanks for the correction Garrett
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4g4drb17 »</TD></TR><TR><TD CLASS="quote">i would want to do the zc si hybrid will that change anything</TD></TR></TABLE>
The ZC half shaft is bolt on on the d16a6
the JDM ZC intermediate shaft is the only one that fits correctly - if you are putting the Si final drive in the ZC transmission, no problem with intermediate shaft since you are only changing ring gear and countershaft - 90-93 Integra axles
Re: dohc zc half shaft (jlicrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx »</TD></TR><TR><TD CLASS="quote">the JDM ZC intermediate shaft is the only one that fits correctly - if you are putting the Si final drive in the ZC transmission, no problem with intermediate shaft since you are only changing ring gear and countershaft - 90-93 Integra axles</TD></TR></TABLE>
THis is exactly what I try to explain
i heard from a guy that i respect that the 88 to 89 teg axles are the right ones, does anyone know for sure that the 90 to 93 axels are the right ones
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4g4drb17 »</TD></TR><TR><TD CLASS="quote">i heard from a guy that i respect that the 88 to 89 teg axles are the right ones, does anyone know for sure that the 90 to 93 axels are the right ones</TD></TR></TABLE>
90-93 = correct
ALSO
awd wagon half shaft "should" work. I talked to a guy that said he lined up a zc and a 4wd one and they were identical
90-93 = correct
ALSO
Re: dohc zc half shaft (d357r0y)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d357r0y »</TD></TR><TR><TD CLASS="quote">
90-93 = correct
ALSO
awd wagon half shaft "should" work. I talked to a guy that said he lined up a zc and a 4wd one and they were identical </TD></TR></TABLE>
does anyone know if the awd half shaft part is true?
90-93 = correct
ALSO
90-93 teg axles only, the 88-89 axles are to short.
And I didn't hear this from somebody I tried it myself, the 4WD wagon shaft DOES NOT work.
djphonics
02-26-2007 11:37 AM
PhatHardy
01-05-2003 08:03 PM
