Why is low compression Betta!?
Old May 15, 2002 | 02:30 PM
Ragezero76's Avatar
Default Why is low compression Betta!?
i am getting the B18A and putting a t-25 garret turbo on it....the engines compression is in the 9's now. i want to put 8:5 pistons in it....why is this better? i know it helps the engine handel more boost.
Old May 15, 2002 | 02:38 PM
dbman96's Avatar
New User
Default Re: Why is low compression Betta!? (Ragezero76)
low compression is not better. how's that for an answer?
Old May 15, 2002 | 03:37 PM
Ragezero76's Avatar
Default Re: Why is low compression Betta!? (dbman96)
now say what? is this tru?
Old May 15, 2002 | 03:42 PM
inspyral's Avatar
lower compression = less chance of detonation = more boost
Old May 15, 2002 | 04:17 PM
Stock@$$GSR's Avatar
Default Re: Why is low compression Betta!? (inspyral)
I thought that lowering the compression just lowers the overall cylinder pressure? From what I understand, a Honda block can only take something like 1600psi, and if you have say a 10:1 compression ratio, you can only run something like 7-8 psi before you start exceeding 1600psi cylinder pressure. When you lower your compression ratio to 8.5:1 for example, you can now run something like 18 psi (not too sure on these numbers here, so don't quote me) and still maintain a cylinder pressure of 1600psi.
On a side note, is there some formula as to how much boost you can run on a certain compression ratio? For example, if I had say an 11:1 compression ratio, how much boost can I run before I blow something up?
michaelcal12
Honda Civic (2001 - 2005)
Dec 13, 2012 07:49 AM
buddy190
Mar 27, 2009 05:03 PM
slowcrx954
Nov 23, 2006 07:49 AM
TehMoonRulz
May 16, 2005 01:15 PM
s0liDyNe
Jul 19, 2003 10:24 PM
