Need help with specs for block build h22
Old May 14, 2002 | 09:55 AM
guyuenvy's Avatar
Default Need help with specs for block build h22
ITs a 2001 h22 block
Got darton sleeves sitting here
eagle rods
je pistons
prodrive oil pump
the machine shop asked me for specs for the build so anyone know what i should tell them?
Old May 14, 2002 | 10:42 AM
apexii's Avatar
Default Re: Need help with specs for block build h22 (guyuenvy)
Wow, where to start.
Do you have the specs on the pistons? Are they stock bore? If so, they require an 87mm bore, there are also 87.5mm je pistons for h22's. The eagle rods for h22's require size 2 bearings. The prodrive oil pump should be self explanitory.
What specific specs is he looking for?
Old May 14, 2002 | 12:00 PM
DirtyLude's Avatar
Default Re: Need help with specs for block build h22 (apexii)
A spec sheet should have come with the pistons. If it did not, then ask JE to fax a spec sheet for you which includes clearances.
KdrewsBB6
Sep 9, 2014 11:08 PM
mudpuppy4life
Aug 5, 2011 08:48 AM
dominate9
Jul 4, 2005 09:56 AM
Fly1865
Feb 7, 2004 09:55 PM
dennis
Sep 3, 2003 04:54 PM
